SL/SLC-Class (R107) 1971-1989 : 250SL, 280SL, 450 SL, 380 SLC, 450 SL, 380 SL, 560 SL
SL/R107: Pesky ancient brittle engine bay vaccum lines
Old Jul 10, 2024 | 09:55 AM
mytoolman's Avatar
1976 MBZ 450SL, 1955 Ford C600, 1972 Ford F250,1973 Superior Motor Coach
Good day all!
I'm owned by a 1976 450SL.
Every hard type vacuum line is original . Just a touch can break them.
is there a kit available to replace this plethera of vaccum spaghetti that permeates the engine bay of this automobile?
Is there an aftermarket kit using something nicer like high heat silicone tubing out there?
Examples of the things that need replacement
Old Jul 10, 2024 | 11:11 PM
Max Blast's Avatar
NGL450 w/EORP, S550
This is a pretty standard product that’s still available, you may also find it by looking at different manufacturers air suspension air lines.
LOL@intro. Don’t give that car your lunch money.
Old Jul 11, 2024 | 06:17 AM
ygmn's Avatar
2015 E400 Sedan
I saw on some car show where they were redoing an old MB wagon and he bought some vacuum line fitting kit and just a soebulk vacuum lines in various IDs.
Probablynot gonna find a kit unless you go to the MB classic part store thingy in California I have read about.
Change the hoses and fittings as both get brittle over time.
Amazon and other online stores have tons of stuff:
Tubing and Hose from Cole-Parmer (coleparmer.com)
Amazon.com: 1/8" 5/32" 3/16" 1/4" 5/16" 3/8" High Performance Automotive Silicone Vacuum Tubing Hose line Kit 6PCS 5FT with 115PCS Nylon Vacuum Connectors (Blue) : Automotive Amazon.com: 1/8" 5/32" 3/16" 1/4" 5/16" 3/8" High Performance Automotive Silicone Vacuum Tubing Hose line Kit 6PCS 5FT with 115PCS Nylon Vacuum Connectors (Blue) : Automotive
Amazon.com: 115PCS Car Vacuum Hose Connector Assortment,12 Sizes Vacuum Tube Vacuum Line Kit with Tee/Straight/Reducer Connector,Heat Resistant 240℃ (460℉) Car Spare Parts for Car Truck SUV : Automotive Amazon.com: 115PCS Car Vacuum Hose Connector Assortment,12 Sizes Vacuum Tube Vacuum Line Kit with Tee/Straight/Reducer Connector,Heat Resistant 240℃ (460℉) Car Spare Parts for Car Truck SUV : Automotive
Amazon.com: Mercedes (select 72-89 models) Vacuum Line Purple/Yellow 1.0x4.0 mm : Automotive Amazon.com: Mercedes (select 72-89 models) Vacuum Line Purple/Yellow 1.0x4.0 mm : Automotive
WEB Catalog |SMC CORPORATION (smcworld.com)
Good Parts online parts stores:
Pelican Parts Search: vacuum lines
Browse Our Mercedes Benz 450SL Parts Catalog | FCP Euro
gonna be a bit of hunting but worth it in the end
