SL/R107: Engine cut out
Any ideas please
Dave
PS: I own a much earlier 107, so no detailed knowledge of the 300SL
Dave
If the battery maintains acceptable voltage under load, then I would look at the other issues, starting with the battery ground connection. Bad connections will result in low voltages when under load, but not with no load.
Thanks again
Dave
Measuring voltage doesn't tell you much. It may not be a battery problem, but a simple test is required to eliminate it as the issue. Even without a proper tester you can use the lights and other loads on car. These Youtube vdeos are quite good.
I would be careful running an alternator with the wiring disconnected. You can damage it that way.
I have fitted a new alternator and it has solved the problem which was the car was running on battery power only and when that ran out it stopped, hence why it wouldn't turn over when this happened.
Thanks again, Dave
