SL55/63/65/R230 AMG: Wiring Revision for C-Tronic Lowering Module on R230 SL
Pin 42 P1 Block: Yellow/Blue Factory Wire
Pin 20 P1 Block: Yellow/Black Factory Wire
Pin 2 P2 Block: Yellow/Blue Factory Wire
Pin 5 P2 Block: Yellow/Red Factory Wire
The red/blue Carlsson wire still goes through the firewall into the empty Pin 1 of the ESP control unit.
Pin 47 P1 Block is for the red Carlsson wire (+Vcc)
Pin 21 P1 Block is for the black Carlsson wire (Common)
The information above only serves as a guide - as revised by Carlsson, and applies only to the C-Tronic Version 1.
