SL55/63/65/R230 AMG: The best way I found to lower my SL55 ( before and after pictures)
Old Dec 22, 2005 | 03:46 PM
lucky mf's Avatar
SL65
Thanks Docdan
Thanks for the info I called Nash & he was real helpful
Old Dec 22, 2005 | 09:45 PM
Frisco's Avatar
03 CLK500, 04 X3, No 07 GT3RS :(
drop it more!
Old Dec 24, 2005 | 01:54 PM
csumt76's Avatar
LS7 powered Corvette
The car can be lowered using the SDS, and it is pretty simple... There is only so far you can go or else the airmatic control unit will not allow you to calibrate the ride height at the setting you choose. The voltage signal from the ride height sensors must be withing a certain range that is preset into the control unit. After that, there is a special tool you use to measure the inclination angle at all four corners.. basically the angle of the suspension arm at rest. This value you can set to try and make the car a little lower as well. I did it to my 06 E, I will post some pics later. I dont remember exactly how much I got out of it.. The left front wheel was the sensor that kept coming out of range first and not letting me slam it.
Also, I have thought about running some setup to dump the airmatic resevoir, creating a "bagged" effect if you will. Just thought that would be cool to do if I was out at the car show. :p
Old Dec 27, 2005 | 09:12 PM
docdan's Avatar
2007 Porsche 997 GT3
Originally Posted by Frisco
drop it more!
The Tribe has spoken!
j/k. In all actuality, the comments in this thread confirmed a certain feeling that I was having.....that I haven't lowered the car low enough. Part of my reservation in lowering it more was due to all the scraping I had in my lower front spoiler of my NSX when I lowered it. It was very difficult to drive around town without bottoming out.
The SL55 is a little different in that in has 3 different ride height settings. Currently, the height you all see in the pictures is the lowest of the 3 settings.
I just spoke with Atlanta Classic Cars and have arranged for them to lower it even more. I still won't "slam" it. However, I am going to keep the current height as the middle setting, and have a setting that is lower and higher than the current one.
I guess we'll all find out pretty soon if this can be done without causing me any errors or problems. I sure hope not!
Old Jan 1, 2006 | 12:21 AM
PHX55's Avatar
2003 SL55 AMG
Thanks!
Docdan - excellent thread - thank you for sharing all of this information. I recently moved away from the ATL area and will confirm that Atlanta Classic Cars has one of the premier MB shops in that metro area. I was wondering what did Nash do to eliminate the supercharger clutch chirp - assuming it's still gone. I'm now out in Scottsdale, AZ and local MB dealer claims it can't be fixed either.
Old Jan 2, 2006 | 05:46 AM
corkscrew's Avatar
2008 S600, 2006 SL55AMG, 2005 SLK 200K, 2004 S280
Lowered front - parking problems?
Your car looks great lowered. Do you have any problems when going forward into a parking space in a commercial garage where tire butts are in place? I have to be very careful with that in the States. Here in Bangkok it is not a worry as everyone backs into parking slots.
Old Jan 3, 2006 | 10:33 AM
  #32
docdan's Avatar
Originally Posted by PHX55
Docdan - I was wondering what did Nash do to eliminate the supercharger clutch chirp - assuming it's still gone. I'm now out in Scottsdale, AZ and local MB dealer claims it can't be fixed either.
I spoke with Nash regarding this just yesterday. In my particular case, the chirping was caused by worn out supercharger belts. However, he told me in most cases the culprit is the "supercharger idler" that "loses some of its original tension" and should be replaced.
Now, I can do foot surgery with the best of them, but I don't understand supercharger's very well, so I hope this helps you.
Old Jan 3, 2006 | 10:37 AM
  #33
docdan's Avatar
Absolutely no problems with the car being lowered. Having owned a few cars in the past that were very low, I have learned to look ahead at where my car will be turning. I assess the steepness of upcoming driveways, etc.. and raise the height of my car 1 or 2 steps in order to clear the ascent/descent of the driveway.
This same principle could be applied to parking bumpers. Just raise the car up if you're concerned about bumping into things.
Old Jan 3, 2006 | 11:01 AM
  #34
Can Drive 55's Avatar
2005 E55
Beautiful car at any ride height.
Old Jan 9, 2006 | 08:15 PM
  #35
docdan's Avatar
Thanks for the compliment!
Attention Folks reading this thread:
I have continued this thread under a new title with new pictures of the car after it has been lowered again. I got a warning from "Photobucket.com" that I was exceeding my monthly bandwidth on photos. Therefore I am forced to separate the groups of photos. Please click on this link to see the pictures in the new thread.
https://mbworld.org/forums/showthrea...96#post1421796
Old Jan 15, 2012 | 01:04 AM
  #36
silverfox51's Avatar
C230 Kompressor Coupe
DocDan....That ride is SWEEEET! I am from Columbia and will be moving back in a few months. Just curious, what area are you from?
Old Jan 15, 2012 | 06:48 AM
  #37
Maverick1975's Avatar
Vath ML63 Brabus C63 SL63 CLK63BS C63BS
Resurrecting a 6 year old post, that's go to be a record!!
Old Jan 16, 2012 | 08:05 PM
  #38
e500slr's Avatar
2011 E63, 2013 CLS63
First post too
Old Jan 23, 2012 | 12:41 AM
  #39
mikey boy1's Avatar
2011 Mercedes-Benz E63 /////AMG
those wheels are...ahhh... weird..
Old Jan 25, 2012 | 02:33 AM
  #40
freestylebiker3's Avatar
w215 cl65, W212 E63, R53 Mini Cooper JCW, E92 328I
another cheap and safe way to lower the car, as we all know is the lowering links.. about 200-300 dollars you can purchase these links an lower the car to your "flavor" and i dont see why these links woul void warranty
