SL55/63/65/R230 AMG: Command System
04 SL 500, 09 R350, 09 E63, 2010 Prius
You can cchange to the new system. cost for the system without labor is around 2-2.5K. But, you will need to have the center consule paneling trim piece changed to the new one as well, that may be close to 1k... You can get your customs guy to do it for you but he will need to have connections to an MB computer system to link and reset the COMMAND functions from the steering whell... kinda like a programing thing.. not cheap... I looked into doing it but opted to keep my older one with the smaller screen (04') and just got a video upgrade with a separate external DVD player.
good luck!
good luck!
![hammer](https://mbworld.org/forums/images/smilies/bonk.gif)
2004 SL55, 2015 A250d, 2016 GLC250d
Before you do that .. if you have integrated phone or CD changer, or the BOSE sound system, it wont work with the new DVD based COMAND - this is because the old system uses different fibreoptics (D2B) to the new one (MOST).
Also, somehow you need to find out if your cluster can support the DVD based COMAND (since it displays messages on the CLUSTER) vs the CD based COMAND. I *think* my MY2004 one can - but I dont plan to do this change as I have phone. CD and BOSE :-)
Cheers
Richard
Cheers
Richard
good luck!![hammer](https://mbworld.org/forums/images/smilies/bonk.gif)
good luck!
Are you sure? I was looking into doing that to my o4 as well and I was told that I have to change out the entire wiring/cabling from d2b to MOST which cost way more then $2.5k. Did you find a way of doing that without changing out the whole system?
thx
'10 MB E63, '08 ML550 ('05 E55, '05 SL55, '08 E63 GONE)
I have a 2005 center console (burlwood) that I'd be willing to sell pretty cheap if you decide to go that route.
~ Ian
~ Ian
Former Vendor of MBWorld
some slow@$$diesels
NOT worth it!
greetingz,
