SL55/63/65/R230 AMG: 2004 sl55 power loss and transmition sticks
Not to worry, it's a straightforward fix.
Search on the E55 board for comments related to this recall. A pre-service dyno may be in order.
If you don't drive the car hard, you are required to surrender it to someone who will. It's in the fine print of your contract.
i had the car for about two years and i know its not driving right and when the supercharger quits it feels like a honda i paid the extra 40k over a regular sl just to feel the amg supercharger .and they are trying to tell me its normal to have it quit !!!!.i picked up the car late and the techs were gone i'm taking the car tomorow and i will give them 40k worth of rage!!!!!
Which is your dealership? Once I took mine to the MB of Ft. Lauderdale for regular maintenance work and I asked them to check the backlight on the A/C console. When I picked up the car, they told me that I needed to replace the whole console. After doing some research on my own, I bought the key to pull the unit out and found that the bulp needed to be replaced, it cost me only $4.00 to replace it !!!
the same exact thing happened to me last night (05 E55). i took it to the dealer, told my sa all the symptoms, (i thought it was the belt or s/c clutch). the i spoke to a tech after he test drove it. he said everything is normal and the s/c was working fine
.(i hate when they cant replicate the prob.) he said they will hook it up to the diagnistics machine, will it show up on there?thanks
its easy to duplicate the problem you have to floor it for a few miles let the supercharger heat up and then try to floor it again and just like that your driving a minivan
i was not there with the tech when he test drove it they told me he will find the problem for sure not to worry!! yeah right!!!!!
I just sent the following fax to my SA to make sure they fix the problem. (Thanks to Marcus on the E55 board.)
Here is the text from a work order performed on an E55 that had the same power loss problems as mine:
343 WMB (N/C)
541012 Test Program - After Short Test, Perform
343 WMB (N/C)
1 000-500-01-86 PUMP (N/C)
090000 Replace Air Cooler Circulation Pump
343 WMB (N/C)
CODES FOR CIRUCLATION PUMP FOR SUPERCARGER PERFORMED SDS TEST
FOUND CODES FOR AIR COOLER CIRUCLATION PUMP. PERFORMED FUNCTION CHECK PER SDS REPLACED PUMP WITH UPDATED
....if you get stuck pm me and I will scan the star machine printout and mail it to you.
Thats the advantage of having the clutch on the Kompressor engine. Instead of retarding timing and limiting the engines output, you can just kill the supercharger entirely.
The problem has occured on the 32's as well. The coolant pump swap is pretty simple. Had a guy get his replaced at my place of employment because it was making abnormal noises when he parked it in his garage. The close quarters just made the odd sound of the "soon to fail" pump more noticeable. We replaced it no questions asked.
i called my sa and left him a message saying it was the ic pump. he called me later in the day and asked how i knew
. it showed up on the diagnostics.he said that he only had 3 cars w/ that problem (incl. mine), then he was like "some people dont even know its not working b/c they dont get the s/c temp. high enough, we both started cracking up (he has a 2500hp drag car
