SL55/63/65/R230 AMG: Kleemann Stage Question
Old Mar 14, 2007 | 10:40 AM
AzCLS2006's Avatar
RENNTech G55 / Bentley GT / Range Rover / Lambo Superleggera
Ok guys, I am sure this has been covered but cant seem to find the info... What do the 4 stages consist of and what power do each out out
Stage 1 -
Stage 2 -
Stage 3 -
Stage 4 -
Old Mar 14, 2007 | 01:44 PM
BiTurboAmg's Avatar
SL65 AMG
[QUOTE=AzCLS2006;2076621]Ok guys, I am sure this has been covered but cant seem to find the info... What do the 4 stages consist of and what power do each out out
Stage 1 - ECU PULLEY 50hp
Stage 2 - ALL OF STG 1 PLUS HEADERS AND DOWN PIPES 90-100hp
Stage 3 - ALL OF STG 1-2 AND CAMS 100-110hp
Stage 4 - ALL OF STG 1,2,3 AND A TB. 110-120hp
You can also add the tb and ic pump at any time. The hp numbers may be off but give you a good idea of what you can expect.
Old Mar 14, 2007 | 08:04 PM
Mrdredd's Avatar
is that HP to the wheels? and on stage2+ is that the additional power gained from the previous stage or in total gains from previous stages together?
Old Mar 14, 2007 | 08:43 PM
SteveFox's Avatar
Bentley Flying Spur, CL550
As far as I know thats power to the crank. And its total gains from the previous stages together. ie; stage 2=stage 1 + 40-50hp.
Old Mar 14, 2007 | 10:25 PM
BiTurboAmg's Avatar
SL65 AMG
That is crank and it is total power for that stage. So not on top of stage one but stage 1 plus stage to is 90hp. Like I said I know the numbers are not the exact that kleemann has on the website but it is a good idea. When I did the k2 to my e55 I pickep up something like 92hp and 115lbft so if I recall I had right about the qouted hp gain but the lbft was about 10-20 higher then what was quoted. Hope this helps and if I find my dyno I can give exact numbers I gained or do a search on the e55 forum and you can find my post with pre and post dyno results.
Old Mar 14, 2007 | 10:42 PM
AzCLS2006's Avatar
My question now is this: I thought a Stage 1 was also 50+ HP, but Kleemans website states 20hp? I always thought it was the same as Renntech and I know Renntech Stage 1 is like 45-50HP....
Anyone have a Stage 1 Kleemann car? Please advise.... Thx
