SL55/63/65/R230 AMG: Tire pressure monitor
Old Apr 21, 2007 | 12:48 PM
leadfoot's Avatar
Can anyone tell me how this sysyem works.Do you set the system to the PSI you want for your tires.Does the dashboard notify you if one of the tires has a lower PSI then set to?How much PSI does your tire need to lose before you are notified?
Old Apr 21, 2007 | 04:24 PM
sprins's Avatar
G55, SLS, smart eq
I believe that 0.5 bar below the last readout will give a warning. Conversions between bar and psi can be done via Google.
Old Apr 21, 2007 | 07:40 PM
SuperDave's Avatar
05 SL 55 AMG, 01 Turbusa/8.43 @ 183..1/4 mi.
Your tires will lose far too much air before the monitor comes on.............................Do yourself a favor, spend 10 dollars on a decent tire gage and another 300 on a small compressor for your garage.........
You will NEVER have to concern yourself with tire pressure again.........
Monitor and Adjust Accordingly............no tire/car is invunerable to time!!!
