SL55/63/65/R230 AMG: SL55 is no Sports Car
SL55 AMG
Is an intercooler standard on European SL55s?
This is an interesting thread for me - I've recently returned from a 1600mile trip around Spain with a bunch of car nutters in Ferraris, Lotuses, 911s etc. I found the supercharger cutting out quite often on the switchback mountain roads we were driving. I eventually worked out that the S/c was cutting out in the heat, and I looked for any evidence of intercooling, but my UK spec car doesn't appear to have any chargecooling arrangement.
Is an intercooler standard? if so, looks like another warranty claim is on the cards....
with your decision making ability, something even worse might happen sooner for u in the 65..
Thank you all for your comments. No question I mis-judged the traffic - and especially the speed - coming towards me and it shows that even after decades of driving, once in a while, you make a mistake.
I don't think the SL55 is faulty, we're talking 600 yards, closing speed of 150mph, 8 seconds to complete the overtake.
As for which car is quicker, I'm not about to abuse them by testing them, but through the seat of my pants, the 911 feels the more agile. YMMV.
'03 E55
If you have a S/C 55 engine then you should take it to the dealer and tell them that the Intercooler Pump is faulty and needs replacement. It is the most common problem with these cars.
#32
SL55 AMG
Interesting - I have spoken to my dealer and they told me it is not a fault, but a safety feature - But the tone of replies to my questions didn't fill me with confidence that they knew what they were talking about. I'm going to try again with another source of information - I'm e-mailing AMG...
#33
'03 E55
My dealer could find no error codes or anything within the car that told them that a problem existed. I took the technician for a drive to see the result of the SC shutting down. He replaced the pump immediately.
#35
SL55AMG, ML420CDI, E320TCDI
Blue,,, you are getting old.
If you by now dont know what your SL55 is capable of and what not, you are in big trouble.
How long have you had that car, 5 years i think ?
Admit it, you missjudged the situation, and now you are blaming the car. Drivers error clearly.
![smash](https://mbworld.org/forums/images/smilies/smashfreak.gif)
#37
Almost had a major accident yesterday after I under-estimated how long it would take to pass a truck (on an undivided road) and pull in safely in the face of another truck coming the other way.
Turned out the SL55 seemingly took forever to get past the truck even though I had preselected 3rd gear, and the turn in to get back in lane was pretty soggy. Only just made it.
Haven't been using the SL55 much recently and this heart-stopping moment convinced me the 996 TT is MUCH quicker in a straight line, MUCH more nimble to turn in and, on the roads I drive, a MUCH safer car.
#38
Remedy: Replace IC pump! Pronto!
#39
Nice to see you posting again BlueSL...
I lurk over here on the SL55 board every now and then.
You have been here since the beginning, and helped me diagnose my own issue with the SuperCharger Squeak. I know you know your car.
It seems like the older 2003/4 MY S55 guys have drifted away from that forum and have been replaced by a much younger crowd who waste a lot of keystrokes complaining about posers with fake AMG emblems. It's getting harder to find any real technical knowledge shared on these boards.
Back on topic...
I am curious about whether this same Intercooler Coolant Pump might also have been used in the 2003MY W220 S55AMGs. Anybody with StarTech access know the answer?
Back on topic...
#40
1 Post
2005 SL600, 2011 Honda Odyssey Touring Elite
Back on topic...
Back on topic...
I share your sentiments.
I have the same question about the IC pump in the 600. If you take a look at the RennTech site, the part numbers for the upgraded pump for the 55 and the 600 are silimlar and the price is the same. Could it be the same pump? Is the stock pump the same in the 55 and 600? Was there a change to the design of the pump at some point in order to fix the defect?
#41
SL55 AMG
IC pump
Thanks for the replies everyone - the way I'm ragging mine I think it needs a larger IC pump and possibly an uprated fuel pump as well! ![drive](https://mbworld.org/forums/images/smilies/driving.gif)
I'll have a more serious word with the dealer once AMG has replied to me.
Edit: - I've had an e-mail back from AMG, confirming it as a known fault. So, off to the dealer for a replacement!
#42
1 Post
On a separate note, the throttle response in my 600 was feeling a bit sluggish, so yesterday I did the "ECU reset" that was described on the boards last year. It worked wonders, the car responds much faster. For those who don't know about it, here are the instructions as described by Jakpro:
1. Turn the ignition key to the on (not start) position. (two clicks)
2. Press the gas pedal to the floor and hold for five seconds.
3. Turn the key to the "off" position (don't remove the key), then release the gas pedal.
4. Wait at least two minutes for ECU to reset.
BlueSL, give this a try if you haven't already... I would like to hear your thoughts.
#43
It may appear that way on the surface, but you must keep in mind that 493 and 420 are PEAK numbers. We all know the 55 motors are underrated from the factory, but even discounting that, the MB motor makes more torque over a broader RPM range than the 996TT.
#46
SL55 AMG
IC coolant pump - sorted!
Thanks for all the comments. I took my SL55 to my dealer, as well as a copy of the e-mail from AMG confirming the fault. Pump now replaced, and several pulleys, the belt, and belt tensioners were also changed to stop the annoying squeaking noise from the engine when started from cold. Thank goodness for Mercedes warranty!
All I have to do now is go back to mainland Europe and thrash the bollox off the car to see if the pump really is working!
![naughty](https://mbworld.org/forums/images/smilies/naughty.gif)
#47
Also, is the ECU reset as described in this thread for an SL600 also accurate an SL55? Thanks!
#48
It will have high Intake Air Temperatures (IATs) which can be measured with a datalogger.
#49
Thanks for the response...I'm trying to determine if I have an issue with the car, or if it simply doesn't seem as fast now that I've had it a couple of months...
#50
I have a 2006 Z-06 although this 2005 SL55 I have is not as fast it can keep up with it with no problems so I think you have something wrong with your car or the one you traded in. The handling of this car in the sport mode is very good as well and more compliant than the Z-06 on rough roads. I have stepped on it on a few occasions on the highway to see what the SL has and it pulls and pulls with no problems. My only complaint with this car is that it is harder FOR ME to get in and out of than the Z-06 and the seating position is not as comfortable.
