SL55/63/65/R230 AMG: SL55 brake noise,I/C pump ?
Old Sep 14, 2007 | 11:37 AM
cdsjklee's Avatar
2004 SL55 AMG EUROCHARGED. 2002 X5. 1999 SUBURBAN WHIPPLE SUPERCHARGER+MODs,04 M3 EUROCHARED
Angry SL55 brake noise,I/C pump ?
Hi. I have 04 SL55 AMG. Dealer just replaced rotor and pads on all 4 corners, Now every time when I apply brakes it makes scraching noisy. Took the car back to the dealer 3 times but problem still exist. It does not make any noisy when I brake hard but normal stop and go it drives me crazy Can any member have a cure or guide me a direction.
2 days ago I was try to pass the car useing on a two lane road car was going fine but when it hit over 75 mph it was like coughing ? feels like misfiring and did not go that fast so I slowed down. When I drive normal it never did that but this was the only time that I realley push the pedal to the floor. Since then car seems drives slower it does not have the that kick when I take off. other than that the car is awesom. Do you think this is I/C pump problem ?
Old Sep 14, 2007 | 11:42 AM
IngenereAMG's Avatar
SL55AMG, Ferrari 348, Ferrari Testarossa, Ferrari F40, Ferrari Mondial t, Ducati 916, Indycar
The brake noise sounds like they could just need bedding in.
The performance issue could be the IC pump. It sounds like a trip to the dealer is in order!
Old Sep 14, 2007 | 11:50 AM
cdsjklee's Avatar
What is the bedding in ? Can I do that or need to go to dealer ?
on performance issue do you think it is the I/C problem is there any way to check. thanks
