SL55/63/65/R230 AMG: Help adjusting clock 03 SL55
Old Nov 9, 2007 | 09:58 PM
noop's Avatar
I have an aftermarket headunit (Eclipse 5495 replaced Comand), and I do not know how to adjust the time. Manual says it could be done with the Comand unit, but I no longer have that. I have also tried from the steering wheel controls but the only time option that comes up is 12-hour or 24-hour.
My clock is 3 hours behind, and it's really buggin' me.
Old May 5, 2009 | 03:42 AM
misterlawyer's Avatar
2003 SL55 Silver/Charcoal Pano,K-Go,Bi-Xenon,Phone,AC Seats,
Sorry for reviving such an old post, but I'm considering a new head unit to replace my COMAND and I'm trying to avoid any potential issues like this one.
Anyone know how to adjust the clock when the stock COMAND unit is gone?
Old Jun 28, 2009 | 01:18 PM
wickedrsr's Avatar
10 R8 4.2 ,11 E350, 03 SL55 SOLD, 02 M3 SOLD, 95 NSX SOLD
Anyone have a fix for this?
i have the same problem.
Old Jun 28, 2009 | 01:48 PM
BeltFedBob's Avatar
From: Lynnwood in summer, Fountain Hills during the rainy season in Wa.
2008 Maserati QP EGT, 2005 SL55AMG , 2002 CLK55AMG 2002 C230K Coupe
Bummer dudes. On the 03 the GPS and command head set the time. Need to crack out the Rolex. Don't know if the SDS will do it. Pg 122 in your manual, pg195 command manual.
On the 05 you select on the command or turn it off. (time sync) then you can set it manually. pg 149 in the 05 manual.
Old Jun 28, 2009 | 02:05 PM
wickedrsr's Avatar
Only thing i can think of it is when its 12:00 unplug the clock and plug it back in to sync 12:00? This should reset the clock... might this be the only way?
