SL55/63/65/R230 AMG: I have rubbing with my new 305..
Old Apr 16, 2008 | 10:20 PM
htn's Avatar
htn
sl55
Originally Posted by CY
I had my SL slammed for a while on 305/25/20 tires in the rear with no issues at all except a very uncomfortable ride. With a pefect wheel offset you should have no rubbing at all.
do u happen to know what's the perfect offsets????
Old Apr 17, 2008 | 06:53 AM
maxabo's Avatar
2008 MB CL600. 2020 MB E300 de. 1987 BMW M535i.
As I stated earlier on this thread;
My 305/25-20 on 11" with ET35 rear, don't rubb. At all.
Old May 7, 2008 | 08:06 PM
charles pearson's Avatar
SL55, CL55, Range Rover, Lexus LX470
I truly believe that it is all in the tire selction as far as what brand tire ur using, some tires have thicker tread and ride higher than others. The same concept that I ran into when I mounted a certain Falken tire to my 20x8.5 it was not a wide enough tire but the proper size tire, I had to return them and traded off for some Nitto 555 and they fit perfectly and were the same size tires as were the Falkens just not as wide due to the build quality of the tire. Tires can be tricky I suggest asking someone here who runs the same wheel size as urs and ask them what brand tires they are running. Hope U get squared away.
Old May 7, 2008 | 11:41 PM
CY's Avatar
CY
SL/M6
Depending on the lip size and width of the wheel the offsets varies...basically some wheels are built for these cars others arent. Everyone seems to run 305/25/20 with no issues. 295/30/20 isnt as common it seems.
