SL55/63/65/R230 AMG: wheel advice please
Thanks for a terrific forum and any insight will be greatly appreciated.
There are several issues with trying to do what you are describing.
18" wheels should clear the SL65's smaller rear rotors but it's unknown (at least to me) whether the brake calipers are set up to clear 18" wheels. Since you have both the car and 18" wheels you can try it and see if there's room. If there's an obstruction, it should be pretty obvious.
Beyond that, S600 wheels usually have a much larger offset than SL wheels, mid-40s versus low 30s. That's going to move the wheel about 1/2" toward the center of the car and may create a rubbing problem, especially with the drag radial's sidewall flex. You'll almost certainly want to use wheels with less offset.
Finally there's the issue of tire circumference. If the front and rear tires have significantly different circumferences then the wheels will rotate at different speeds. Some posters have suggested that difference in rotating speeds may cause the ESP system to engage even though the tires aren't actually slipping. If it was me, I'd try to keep the circumferences within 1% or 2%.
Good luck and enjoy! SL65 is an awesome car!
