SL55/63/65/R230 AMG: Can I fit this steering wheel ?
If I was to purchase this
http://cgi.ebay.com/ebaymotors/Merce...Q5fAccessories
Would I be able to fit it to me 2003 sl55 without to much fuss?
Well, it fits, sure.
But don't expect the paddles to work, because there, I'm not too sure!
It's been said/written here that a guy in the Netherlands can fix that though...
And since I have that same steering wheel that you are about to buy in my 2005 SL600 (without shifting possibillities there at all), I kinda hope it's true..!
I cant beleive that mercedes would actually make the shifter buttons and paddles electrically different ?
There is a local mb expert working on paddles for our cars. He currently has the wheel off my 65 and has successfully put together a set of paddles using all OEM parts. I believe he is planning on offering this service publically just as soon as we can test it and make sure there are no glitches.
Agree 100% shifter buttons on the R230 are incredibly stupid.
-m
The airbag you have today fits on the flat bottom wheel too, no problem there!
But I'm sorry to say, that you'll have the same trouble with that last wheel also, since it has paddles...
And the reason for that, I think, is because on the wheel with buttons you can shift up/down on both sides.
But on wheels with paddles, there's up-shift on one side, and down-shift on the other...
That can at least be a part of the reason why.
The picture in my profile is actually at stock height for the 65. I will be using the STAR/DAS to lower the car, the same way I did for the E55.
When the 65 comes out of hibernation it will look quite a bit different than it does in my sig pic.
-m
I know this for sure, since they work in my car. I have a 2007 AMG performance steering wheel in my 04 SL55. It was a tough road to find someone to modify the paddles.
Unfortunately, that guy doesn't modify the paddles anymore, since it seems to be just to much of a hassle to get the job done.
As for the original question: Yes, the steering wheel works. You will be able to use your old airbag and the buttons to control your COMAND will work too.
The paddles DO NOT work, but they also DO NOT cause any problems. You do not get any error messages from them or so. They just don't work.
That's simply not true. Do you actually drive an AMG car? What you said is true for Porsche's Tiptronic. But on AMG cars with "buttons" you have an upshift only and a downshift only button (just like the paddles).
My mistake!
Mix up! I'm thinking of BMW 745...
Sorry!
As I stated earlier, my SL600 doesn't have that.
But I've driven AMG's, of course, I just had a mental lapsus..!
But I'm sooo hoping that the guy from Netherlands can get my paddles to work...
Can I use my origianl air bag?
Thank you very much.
