SL55/63/65/R230 AMG: SL600 Weight of seats
So you and Vadim were able to find suitable structural steel at shoulder level near the speakers. I'll have to go looking for that.
Thanks again for the info and would love to see pics when you get them. If I figure out anything additional that might be useful to the forum, I'll post it here.
P.s.
I presume these are the Evosport brackets that you mentioned: http://www.evosport.com/product/prod...VO.INT.BMW.SM1
If so, I can see both why you would use them in the first place and why you would want to upgrade to custom brackets.
Basically what I did to solve the seat bracket problem, thanks to Jrcart, was I purchased EvoSports universal BMW seat bracket(they are pretty heavy). You will need alter the seat bracket with a drill so that the holes align properly to floor. You might also need to alter the holes on the seat bracket for the seat "slider" to bolt up properly.
This seat bracket is also where I bolted up two hooks, one on each side, for the seat belt harness (the bottom two of the 4 point harness).
Next, thanks to Vadim's crew, they made a custom plate bracket that bolts up directly behind the seat at shoulder level. Note it is very important the shoulder part of the seat belt bolts up at or near shoulder level for safety reasons to help avoid neck/spinal injury in a collision. We removed the vinyl cover and it bolted up right underneath the speakers. This custom plate bracket is where we bolted up the other two hooks to complete the 4 point harness.
Hope this helps guys, until I finish cleaning up my racing seat project and post up some pics.
