SL55/63/65/R230 AMG: Squealing / squeaky belt when cold - fixed!
Found a fix! While the engine is running, using an aerosol can of silicone spray (with the red tube extension attached to the nozzle), lightly spray the v-grove side of the belt. For me, the squeal instantly went away.
I gave it a few more light sprays for good measure. Yay!
For the real fix, I think I need new belts and the pulleys need cleaning prior to installing the new belts. I read somewhere that after taking the old belts off, to clean the pulley surfaces with a scotchbrite pad, degreaser / brake cleaner to make sure no contaminants are on the pulley.
I've been searching, but I cannot find a DIY on belt replacement... waiting for my service manual to arrive.
My SL55 had the same very loud and HORRENDOUS belt squeal and several MB dealers were unable to fix the problem! They replaced the belts,pulley, idlers etc and the squeal kept coming back. After a while it got much worse and would last longer. It would SQEEEEEK AND SQEEEEEAL in the mornings up to 5 minutes or 5 miles. This was both very annoying and embarrasing in a $135,000 Mercedes
There was absolutely not doubt it was from the belts as opposed to a bad bearing in the idler or pulley etc, because as you discovered the second you spray the belt with lubricant the noise instantly disappears! But the dealers were totally baffled and unable to fix the squeal after numerous attempts.
The silicon spray works great but only for a few days. I kept the can in the trunk.
I hope that you have better LUCK finding the problem or just keep a can of silicon spray handy!
I'm glad you posted, because my belts look just fine and I was going to try replacing them.
I'm wondering if there is an "alignment" problem... i.e. if all the pulleys are plumb with each other and on the same vertical plane. There's got to be a way to fix... I can live with the "chirp" of the SC engaging, but the squeal during warmup is driving me nuts!
Obviously a laymen who drives a Mercedes knows nothing about things mechanical and they blew my ideas off! They kept throwing parts at it and even tried to order the wrong size belt (smaller) from a C class. I told them this was a Mickey Mouse band aid attempt to fix the problem and would never work..
Of coarse when the C class belt finally arrived from Germany it would not fit....What a surprise!
The MB dealer finally admitted that they had tried everything and had no other ideas and needed more time (up to a month) to try and figure out what was causing the squeal.
That was the last time I saw my SL55...
Both belts are available for about $ 30.00 Ea. I would also check the idler pulleys. I just replaced my dual idler unit that supports both belts myself.
That part is a little bit over $ 400.00 list. Not too keen on spraying anything on these belts. If they are in good shape and all the other components are worrking and inline it should be very quiet. Just the noise of the SuperCharger Clutch at idle.
I guess there are different brands of belts you can buy. The supercharger belt I bought was made by CONTITECH (purchased at allmercedes.com for $26) and on the flat side, has a cross-hatched texture to it which I believe helps with grip and helps eliminate squeal.
