SL55/63/65/R230 AMG: Intercooler sprayer
05 C55
not sure how the coolers are set up, but you can do it with c02.
http://www.designengineering.com/pro...asp?m=sc&cid=1
Can you run race gas on a stock ECU/Car ? Anyone have any proof that it works ? Dyno or Track ?
Whatever keys I grab first...
Even 100 octane ?
Thanks man
Co2 or NOS(does the same thing)
Thanks man
Interesting idea, I tried spraying nitrous on my heat exchanger a while back but spraying the intercooler itself is the way to go. Lower temp IAT's = more power!
SL600 (1000 hp), Cayenne S, 996TT EVO GT750, F430 Spyder,A real Ford GT, 08 Gallardo Spyder
OCTANE: OEM ecu programming tables allow for up to 94 octane adjustments. After market re-flash such as Renntech allows for 99 octane. Higher octane can be used but ecu will not have adaptive value tables to take advantage of it.
Spray: Depending on the set up, you have be careful with CO2 sprayers. It is very ez for CO2 to get sucked into the intake which obviously causes loss of power (personal experience). NOS is a better choice. Keep in mind the limits of the adaptive tables in the algorithms.
C16: That’s a leaded fuel, which is a strict no no for your system. I can go on and on here but its best you further research this point and you'll get the picture.
MS109 is the highest unleaded octane fuel u can get your hands on with a true r+m/2 octane value of 105.
HP: On average if u have a forced induction engine that is pushing over 500hp, u will net an extra 10%HP, with 100 octane (r+m/2) if u have the flash for it. HP increase is lower for normally aspirated.
