SL55/63/65/R230 AMG: SL 63 marker light install
Old Jul 3, 2009 | 11:52 PM
DES1's Avatar
SL 65
I was wondering if any one out there could give me a few pointers
on replacing the side marker lights on a SL 63.
Thanks in advance.
Old Jul 25, 2009 | 04:26 PM
DES1's Avatar
SL 65
Old Jul 26, 2009 | 06:45 PM
bc brit's Avatar
sl55, range rover sport
side markers
Hi DES 1,
if it is the same method as the sl 55,you need a thin flat bottom srewdriver,fix tape around the paint work of the side marker,then gently insert the screwdriver in between the marker and tap covered body and prise it off.
I would loosen it all round,there are normally a few clips holding it in,be carful not to bust them off,it really is easy,just take your time and put 2 layers of tape on to prevent you from scuffing the paint work.
I am useless at any form of diy,but it took me 4 mins to do both sides.
good luck
happy motoring bc brit
Old Jul 28, 2009 | 01:03 AM
photonut's Avatar
SL63
what is your source?
where did you get this side marker? i am looking for a set of these for my sl63!!
Old Jul 28, 2009 | 01:10 AM
Behike's Avatar
2011 G55
Why don't European models have side markers? They seem to have a simple solid partl which i think looks better.
Old Jul 28, 2009 | 03:40 AM
DES1's Avatar
SL 65
Got them off Ebay. US DOT requires them.
