SL55/63/65/R230 AMG: SRS LIght - HELP...
Old Sep 10, 2009 | 10:47 PM
AhMyGawd's Avatar
SL55 M45 Jeep Commander
SRS LIght - HELP...
Driving to the airport this morning my SRS light and Vist workshop light came on. I had my breifcase on my passenger seat which, i normally do not do. The car sat the rest of the day and when i got back it came on again. Has any one had this problem and how do i fix it?
Thank you
Old Sep 10, 2009 | 11:00 PM
roberthechter's Avatar
2006 SL55 AMG
Just had the same thing happen last week. The SRS light in my case was caused by high resistance in connector under drivers seat. Dealer replaced connector under drivers seat by removing seat for access. The code # for this fault was 9183. It was fixed under warranty. Bob
Old Sep 11, 2009 | 08:18 AM
cal1's Avatar
SL55, ML500 & Acura TL
Same issue on my 03 last year only mine was on the passenger side.
Old Sep 13, 2009 | 02:11 PM
AhMyGawd's Avatar
New issue - My stereo volume now does not work? So, the SRS light is on and stereo volume, CD recognition and Sat radio will not work.
Any suggestions?
Old Aug 11, 2019 | 06:05 PM
Mas88s's Avatar
2003 SL55
I know it's been 10 years since this post but my car is doing the same thing.
Did you ever figure it out?
Thanks, Mark
Old Aug 12, 2019 | 11:37 AM
cal1's Avatar
Thanks, Mark
My recollection is the problem was a bad wiring harness in the seat. Seem to recall it can be from either drivers or passenger side. I had mine replaced with an extended warranty I had on the car. I think this issue was common on a number of different cars. maybe a more detailed search will produce enough info for you to better diagnose the problem. It would be nice if you could get codes read. That would really help.
Good luck
