SL55/63/65/R230 AMG: SL55`s with aftermarket 80mm throttle body?
Old Sep 13, 2009 | 07:23 PM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
If so, you have any codes or idle issues ever? What brand you running?
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Sep 14, 2009 | 12:13 PM
cal1's Avatar
SL55, ML500 & Acura TL
I’m running an 80mm TB I purchased from Vadim (VRP). When I got it, I was surprised to see it said AMG on it. I have since heard that the newer SL55s have 80mm stock TBs, not sure though.
As far as issues go, I did notice a slightly higher idle immediately after the install, but the idle dropped back to normal after a few restarts. I assume the ECU adjusted to the larger TB. No codes thrown.
