SL55/63/65/R230 AMG: Am i imaging things?
It seems as if the car is much quicker and powerful when the command center is shut off?
Is it my imagination or is this a clear indication of an issue that my car is not getting the voltage that it needs when the command is on?
Does the convience battery have that much to do with the vehicle performance or, is it my lack of fundamental mechanical knowledge?
Has anyone experinced this?
if code was for "overvoltage" that means your car sensed over 14.7 volts dc over certain period of time (i forgot).. alternator voltage regulator is usually the culprit.
if you are shutting things down the voltage should go up, so shutting down the command would result in higher voltage if anything else.
your diags do not add up... just drive until you get another error code and bring the car in. overvoltage sometimes are a fluke and you should not be concerned unless it comes back.
alex
