SL55/63/65/R230 AMG: Tilt steering wheel - SL65?
Old Oct 23, 2009 | 06:27 PM
abiazis's Avatar
SL 65 AMG, Porsche 911 (993), 2014 Cayenne GTS, 2013 Toyota Highlander Limited
Question Tilt steering wheel - SL65?
I tried to activate the tilt steering wheel for easier exit from the car through the On Board Computer with no luck.....is there a trick to this....or is the feature in the menu under "convenience", but not activated for this car? Any info helpful.....thanks...
Old Oct 25, 2010 | 12:18 AM
Basa's Avatar
C240
You set this up through the menu from the steering wheel.
Old Oct 25, 2010 | 09:53 AM
velvet fog's Avatar
05 SL500, 02 BMW Z3 (Mrs. VF), 05 FJR1300, 91 ZX-11
Try putting your seat forward and up then see what happens. If the seat is too far back, the comfort access feature doesn't activate because the car thinks you have enough room to get out. I have two different position that I use and the comfort access only works in one.
Old Oct 25, 2010 | 04:37 PM
Basa's Avatar
C240
The other nice thing about MB is that these personal settings can get coded to your key. So let's say there are two people in your family who drive the car, you can use each of the keys to code that person's preferences on.
So whenever s/he has the key in the ignition-on position, the system will remember that person's settings.
