SL55/63/65/R230 AMG: Akebono Brake Pad Squeal
Thanks.
as for the brake lube it goes on the back of the pads wear they make contact with the caliper.
try filing the leading edge of the pad that squeals just a bit to take some of the shrpness off the pad. this may help.
for me i have no squeal at all with the euros. but a tiny amount of squeal in reverse when backing out of the garage. i replaced my oem rotors with drilled and slotted and all the noise stopped. could be a groove in your rotors
