SL55/63/65/R230 AMG: How big is your turbo...
Old Feb 14, 2010 | 02:50 PM
sound 8's Avatar
SL 63 W/B AMG , S600,C220
Does the 600 and the 65 run the same size turbo. I get the feeling that there
quite small, maybe Garret T2 size, which would account for no lag and a maximum of 1.3 bar, it would run out of puff over 1.5 bar. Has anyone fitted
bigger turbos to either the 600 or 65. then you could run up to probably 30psi efficiently
Old Feb 14, 2010 | 04:45 PM
DCMETRO22Z's Avatar
E320
The SL600 And SL65 are both fitted with Borg-Wagner K24 turbos, but the 65's have slighlty bigger Kompressor & Turbine wheels.
On Mercedes V12TT engines, the setup is very particular : The exhaust gas manifold and the turbine wheel housing are casted AS ONE SINGLE PIECE.
Brabus sells an after market manifold/housing, but it's overpriced.
Check the "V12 engine is out" thread by Soulsearcher. He is curently fitting a bigger turbo. A brand new Custom exhaust manifold is fabricated, to allow the turbo to be located deeper in the engine Bay since there is no room for bigger turbos in the Usual place.
Old Feb 15, 2010 | 02:23 PM
sound 8's Avatar
Thanks for the info, neat bit of engineering!
