SL55/63/65/R230 AMG: sl55 rear offset question
Hi guys
I am looking at a used set of wheels for my sl55,,,,and the rear wheels are
19x11 with 39 mm offset,,,Would that offset too high for the rear??? i am worry if they migh rub on the inside (I am thinking using 295/30/19 tire). I used to have a set of lorinser lm-5, and the rear is 20x11 with 31mm offset ad 305/25/20 tire,,,and i didn't have any rubbing problem with those
thanks for the response
Hi guys
19x11 with 39 mm offset,,,Would that offset too high for the rear??? i am worry if they migh rub on the inside. I used to have a set of lorinser lm-5, and the rear is 20x11 with 31mm offset,,,and i didn't have any rubbing problem with those
