SL55/63/65/R230 AMG: 19x9.5 (34)| 19x12(20) Will these work on our Cars???
Old Apr 8, 2010 | 07:39 PM
kamilclk430's Avatar
W215 V12TT Build by Speedriven, W221 S550 4Matic
I own a 2004 SL55 and was wondering if these sizes will work on our cars, I don't mind them poking out a bit, since I will do a low stance and tire strech, along with some camber. 19x9.5 (34)| 19x12(20) (I DONT MIND USING SPACERS)
Let me know
KAMIL
Old Apr 8, 2010 | 09:48 PM
okbarnett's Avatar
Porsche guy who drives SL63 w/ perf pkg AND perf suspension
the 19.5 x 19 will work dont know about the 12 at 20 I would put them on a nd see what they need. probibly add a 10 to 15 spacer
Old Apr 8, 2010 | 09:52 PM
Thanks, do you think they will poke???
Old Apr 9, 2010 | 07:33 PM
okbarnett's Avatar
20 will be to far out. May have to cut down the inside hub base to reduce the 20 to 25 or 30. Youll have to put them on and see
Old Apr 10, 2010 | 12:47 AM
So it is possible to make these work on our cars?? either using spacers or doing slight changes to the car so they fit
Old Apr 10, 2010 | 07:15 AM
andy_meng1024's Avatar
2003 SL55, 2010 C63
It'd already be poking out so no spacers. The amount of spacers used are minused by your wheel offset not plus, for example if you add 10mm spacers to a 20mm offset wheel it'd be 20 - 10 = 10 so you'll have 10mm offset. okbarnett is correct you probably need to cut down the inner hub and it may still be a little poking out. On my 11" HRE I have about 2mm clearence left. The widest wheel I've seen fit on our car is 11.5 inches in the back.
