SL55/63/65/R230 AMG: sl55 AMG 2002 ... HELP))) ENGINE PROBLEM
![Smile](https://mbworld.org/forums/images/icons/icon7.gif)
I HAVE PROBLEMS WITH THE ENGINE (burned 2 Pistons and damage CYLINDER)
PLEASE advise HOW CHEAPER to repair ???
BUY USED ENGINE???
CAN BETTER PUT A CUSTOM PARTS???? Where can I buy them? (Now I have more than 600 HORSES)
SL55AMG, Ferrari 348, Ferrari Testarossa, Ferrari F40, Ferrari Mondial t, Ducati 916, Indycar
Cheap and AMG, are not words that are interchangeable.
It sounds like the car was poorly set and/or abused, as these are pretty durable engines. It may be time to 'pay the piper', and have it fixed, and properly set up, so this doesn't happen again.
SL55, Audi A4, Dodge w/Cummins
Ouch so much for the knock sensors taking over ? How come just those 2 cylinders ? I'd flow the injectors, check the fuel filter and pressure and check the ECU for a bad output stage, also check the wiring as well.
Did you pull the other pistons and see how they looked ?
At least the block is sleeved so you can save it
Marc
Marc
