SL55/63/65/R230 AMG: can anybody balance?
Getting some vibration from one of the wheels. Pretty sure I need tires balanced & I know I need a front end alignment.
I have a near by tire store I've used for years with other mercedes i've owned. Should I have them balance my wheels & align - or is there something about the SL55 that would make it better to take it to the stealership?
But first you have to start with good tires.
If your tires are over 8 or 9K miles, Id bet it wont help balancing them. If they have inside camber wear, or not much tread lift no balancing will help for the couple thousand miles they have left.
The road force balancer is a good balancer, but it is intended to balance a wheel and tire that has mis match issues. Like a wheel that is out of round- it will show how to index the tire to it , to make the whole assembly more even or square. Or a tire that is out of round, or lop-sided, it will show how to index it to the wheel to make the whole assembly more square.
Yes its a good balancer, but you always start out balancing the wheel traditionally, then if it shows it is out of spec, it will then go to the road force mode and try to determine if the wheel or tire is the problem, then suggest how to fix it.
