SL55/63/65/R230 AMG: Running at Watkins Glen, any suggestions?
I'm running my 2005 SL 65 with RennTech Stage 2 at the 3 day DE Porsche event at Watkins Glen, NY this weekend and the 4 day Ferrari event the following weekend. Any suggestions about how the car will handle the track? First time doing something like this with my own car. I've b
een to two Mercedes AMG Driving Acadamys but this should be a little different. Not sure about tire pressure, pretty sure keeping car in Sport mode and will be keeping it in manual and using F1 shifters on steering wheel. Should be a ton of fun but would love to hear from some of you that have done this before. Thanks in advance!!!
Some thoughts:
1) don't worry about the car, or the settings, shifters etc...just make sure you have fresh brake pads, and fluid, and check your rotors. make sure all the nuts and bolts are tight, and set your air pressures according to the conditions on the day, if you have a tire temp gauge you can use that as well to check the heat distribution in the tires.
2) The car is much more capable than you will be if you are just starting out, do not try to overdrive the car, listen to your instructor. The Glen does not have a lot of runoff...outside of a couple of areas like T1 or the toe of the boot, should you go off track you will more than likely hit blue armco/guardrail and damage your car and the track (the track will send you a bill by the way).
3) You car, SL65, is very heavy and understeers on corner entry significantly. Check brakes periodicly, check tire wear, and keep an eye on pressures.
4) have fun, be safe ...and try to learn, you will be processing things at a high rate, especially at the Glen, it's a fast high horsepower suited track, lots happen very quickly...don't worry about the settings and gadgetry on the car...focus on things like vision, pedal transtions, smoothness, steering, brake and throttle inputs...those are all basic things that are of paramount importance on a road course.
