SL55/63/65/R230 AMG: Service frequency in low milage
Did a B service in Jan just after buying the car and few months ago when IC pump went bad my SA discouraged me from doing an early service.
Would you the 10K miles service once a year? just an oil change? or wait?
I don't mind dropping $1k/yr if it would make the car last longer. I plan on keeping it indefinitely
It also depends on how you drive those 5000 miles. Driving 'hard' (high revs) and for longer trips seems to be better than constantly driving like an old lady going grocery shopping, on the short term (between service).
-ROOK
I also depends strongly on your driving habits - if you mostly drive the car to full warm-up (20 miles!) and than some, the moisture in the oil can evaporate, keeping the oil from forming sludge. Also remember that in your car the two snails attached to the exhaust manifolds add considerably more stress to the oil compared to non-turbo engines, here it is the question of frequent shut-down that matters (oil gets cooked in the bearing housings
)Did a B service in Jan just after buying the car and few months ago when IC pump went bad my SA discouraged me from doing an early service.
In terms of driving habits, I try to drive few (2-4) times a month to work (100 miles round trip), interleaved with some shot trips inside the city. I only push hard after the engine warmed up nicely and try to minimize shut downs.
On that note, would you rather let the engine idle 5 minutes waiting for a quick errand to finish or shut it down and restart?
