SL55/63/65/R230 AMG: SL55 AMG -02 => SRS mailfunction
W212 Estate 220CDI 2013mod Sport chassis Avantgarde/AMG bodywork +++ Trimmed with BSR PPC Step 3
SL55 AMG, srs-faulty, I think it was faultcode B1859, "the resistans in circuit B12/13 in main air bag driver is to high???.... I didn`t remember the message from the Star Diagnose exactualy, and now the ignition is off.. We have change the air bag to a new one, but no, the same fault code is still there. And sadly we don`t hve the equipment cables to test the wiring in the system... So can you guys plesase help me??? It has to be finish tomorrow :/ Regards Trond, Oslo, Norway...
Possibly bad connectors instead of the airbag itself? I would double check to make sure all contact points are clean and not bent before replacing any parts.
E 63S Wagon Renntech, E55 Renntech, SL65, SL 55 030, ML, bunch of old ones--they come, they go...
That is....
absolutely correct. Just had it done on my 03 before I sold it. I't s not very expensive, you may want to do both sides as a preemptive move.
I can't seem to find the fault codes for the connectors under the seats being out and unfortunately I don't have my service DVD handy. IIRC, there was a code for both passenger and drivers side sonnectors and Im pretty sure the description said something about a squib and it specifically mentioned the seats, which leads me to believe the OP is having a different issue.
