SL55/63/65/R230 AMG: SL mirror side marker....
E 63S Wagon Renntech, E55 Renntech, SL65, SL 55 030, ML, bunch of old ones--they come, they go...
I have one that is cracked....but haven't replaced one of these myself. Can someone give me a little insight or point me to a post? thanks....
There are threads on this, but basically you remove enough of the plastic fender liner plugs to pull the fender liner away from the fender. You then reach inside and compress the plastic flange and push out the marker. You don't need to remove the wheel. If you have the new one you will see the flange I'm referring to. You cannot remove it from the exterior or you will break it. It's actually very easy and quick. This applies to an '07, and I don't know about other years.
Thanks,
but no. Read closely--MIRROR side marker. Done the fronts lots of times.
Thanks for trying....
