SL55/63/65/R230 AMG: Coil over conversion. Anyone making it?
his response was "" sorry . i was out a couple of days . the sl500 kit would put it at 28 1/2 plus or minus an 1/2 inch all the way around ""
See the above, previous posts. I sent pics of my SL55 with a tape measure at the top of the wheel arch in the 'normal' (low) ABS position and of the 'medium' and 'high' setting.
Normal with ABS the wheel arch is 26 1/2. Medium is ~ 27 1/4 and the ABC high setting on a stock SL55 is about ~ 27 3/4. So, he is saying that the SL500 kit would put the SL55 at 28 - 29 inches. At best that is 1/4 inch ABOVE the higest ABC setting on a stock suspension. At worst, it raises the 'HIGH stock' ABC by 1 1/4 inches. Way to high.
Any thoughts, anyone?
Interesting. Let me email Brad Walker @ strutmasters and see what he says.
It wouldn't be a bad idea if you and others show an interest in the coilover conversion for your/our sl55s.
The more interest Strutmasters see ... the better.
I email Brad @ this address (strutmasters addy): brad@strutmasters.com .
only way the spring rate would rise due to adjusting a lower collar is if the strut was in full extension at drive height and would have to be a progressive spring. just to clarify.
so you could cut a coil off and get a drop and raise spring rate a touch. cheap and easy. custom springs would run about $100-150 each. but you really need to know what your doing to get uncompressed heights and spring rates correct.
My last email to him said:
"" Isn't there a spring with the proper rates that would leave the ride height at about 27 1/4 to 27 12/ available? When you say " the sl500 kit would put it at 28
> 1/2 plus or minus an 1/2 inch all the way around " Is that based on the height of my car Vs the height of an SL500 - from stock height to converted height?
Is it really that much heavier than the SL500, both front & rear? I would think the rear would be the same for both cars. A shorter spring, with the proper rates, is the only way I can see to solve what would be an unreasonable ride height for the kit in an SL55.""
I haven't gotten a reply yet.
Your thoughts?
Check out Strutmasters.com on their SL55 'kit'. You are right. If it is a coilover shock it is adjustable. I don't know why Strutmasters just don't explain themselves on the 'sameness or differences' of the SL500 kit and the same kit on the SL55 since the chassis are the same with the ABC.
Give brad@strutmasters a call ""
you can reach me at 877-836-4648 . just ask for brad ""
Deal with them directly. I have a feeling the 'kit' is the same for the SL500 as for the SL55. Bet they just swap right in.... and adjust to what you need.
Call them. Keep us advised.
That being said... bet that lopping off one coil would lower the SL500 kit perfectly for the SL55 since brad@strutmasters.com said that the SL500 kit would raise the front & rear of our SL55s by about an inch. Looks like it would work to me.
Thoughts ?/ comments ??
thoughts ??
i could not imagine the sl500 and sl55 being any real measureable difference in weight balance. my guess is they are using around a 400lb per inch spring so it would take 400lbs to make that one inch difference.
it is sounding like they don't want to deal with it much and may take more pushing and questions to make it reality, but it sounds close.
I have sent the following e-mail to KW Suspension GmBH:
I do believe I am contacting the right place to help us find a solution for the problems of the ABC Hydraulic system. Too many owners are facing regular failures in the ABC hydraulic system.
I am here to inform you that I am one of tens, or even hundreds who would be potential buyers of your conversion kit if done. I would like you to have a look on this thread: Coil over conversion. Anyone making it?
This thread mentioned above is one of many. Too many of us the SL55 are in need of a coilovers conversion instead of the hydraulic system.
Thank you a lot for your time reading this, and I really hope you consider this request as I am a fan of KW products.
Best Regards,
Jad
Read more: https://mbworld.org/forums/sl55-amg-...#ixzz2uKlfcy7D
Lets hope a reputable suspension company helps us find a conversion kit for our ****ING ABC SYSTEM!!
And I would like you to send them something similar at technik@kwautomotive.de
Also can someone show in detail diagrams what suspension components the SL BS has?
