SL55/63/65/R230 AMG: Annoyed by the chirp...where is supercharger clutch located?
https://mbworld.org/forums/sl55-amg-...ger-chirp.html
I hate the damn chirp. Definitely not something I want to live with for long. Could it indeed just be the bearing (which I assume I could use the Nachi one)?
Or would it need shimming?
I guess I can live with the chirp if it really isn't part of a bigger problem. There seems to be no real consensus among the threads I've seen in the archives....seems everyone had this issue and it was looked at as normal (or at the very least....annoying....but not detrimental to the car).
Some people from the rice-racer faction would cut their left hand off, just to have that "noise".
The dealer told me it was not abnormal and the clutch chirp will not hurt anything. Apparently, an early fix was a set of shims. I think there are a few members who have had success with them. I tried them and they stopped the chirp for about a month. I then lived with the chirp until the bearing you see in the photo failed. At that point, I replaced the whole clutch pack and have not had issues since (two years ago). The old clutch pack showed heavy wear on the mating surfaces. That is still what makes me think it was the source of the chirp.
I think they are spraying graphite right on the clutch surface from the sound of it. You might PM Aluthman and make sure. If the chirp comes from violent engagement, then I guess it makes sense.
It seems to me that the chirp puts more stress on the already vulnerable clutch bearing. You don't want to see your bearing looking like the one in my picture. I recommend to anyone living with the SC chirp to inspect the bearing periodically.
I had it on my first SL55 and since I bought that one (used) from MB, it was still under warranty. Back then I had no idea where it was coming from... so I had it replaced with the new clutch under warranty. I simply claimed that the "noise" wasn't there, when I bought that thing (two weeks earlier).
I'm a customer for around 20 yrs at the same dealership, always have my cars inspected on the recommended schedule, so I guess MB calls me a good customer. I guess that also comes in, as they decided to replace my clutch with that 2006 updated one at no costs for me. For a non-known customer they might just have said: "It's normal. Live with it!".
My current SL55 (a 2004 model) does not have that chirp. So either the previous owner took some measures or it simply didn't turn up on that specific car (as not all 55er have it... no matter how old they are).
