SL55/63/65/R230 AMG: Automatic Tire Pressure Measurements – Faulty or just out of battery?
I have an issue with the automatic tire pressure control which I have been reading could be an problem with earlier models (mine is a 2003)
When I bought this car in April it come up with a faulty tire pressure control – then I put the car in for service and I think (I’m not 100% sure) but think I did see measurements at collect – but the day after it came up with “visit MB workshop” – and ever since.
I can activate the system while driving but there’s no readings – anyone have experience with this?
Could it be as simple as the control units in the tires simply are out of battery?
Any help is appreciated since the alarms are driving me nuts
I got fed up with mine and false readings and I took it all away in STAR
In the USA I ordered 4 sensors from The Tire Rack (tirerack.com) at $75.00 each ($300 for the lot). I was having new tires installed and had the sensors replaced at that time. Once the new ones are in you reset the system from the screen for tire pressure. Do this while driving. The system picks up the new sensors after about 10 - 20 minutes of driving.
What Mercedes charges for this is grotesque.
Make sure you don't have any of the old, removed, sensors left in the car (like in the trunk) or the system gets confused from conflicting signals.
I also have a S550. Went through a similar procedure for it (the S550 uses Siemens sensors).
I’m not planning to deactivate the system since I’m looking for new AMG wheels – found some used one - 1 year old from a SL65 - so the battery in the sensors should be OK – hopefully it will work with my sl55 – just the price have to be right……..
