SL55/63/65/R230 AMG: Lower Suspension bush knocking..... Not replaceable?!
I had it serviced at Mercedes last week and they advised that it could be the lower suspension ball joint, but what they are also saying is that the bush is not available as a seperate part, I have to replace the whole shock?!!! - which obviously isnt cheap!!!!!
Can anyone shed some light into this or are they correct? I'm hoping that perhaps even though a main agent cannot supply another company may be able to help, as the shock itself is absolutely fine!
Does anyone have a diagram of the front suspension setup so I can see what they are talking about?
is this a common thing to fail or could it be anything else?
it could be other things though.
does the knock changes with temperature? (ie knocks less when the car warms up?) if it does - it is a bushing. if it does not and always sounds the same- it is very likely the lower balljoint which is a separate part...
also have them check the tightness of the big nut on the top of the shock. those become lose for some reason and then there is a knock that when you plug the chassis ears sounds like it comes from the bottom of the shock for some bazaar reason.
