SL55/63/65/R230 AMG: tire pressure monitoring system - SL65
I'm surprised the TPMS didn't alert me to the error. The TPMS on my M5 was overly sensitive and would complain if I was 2 lbs different that corresponding wheel.
I know for a fact that the batteries only last for 5-6 years. Then they just conk out. No CEL warnings or anything.
A few may disagree, but I'm certain Tire Rack's TPMS sensors work with almost all Mercedes.....but I am not sure if they only sell the sensors or if you would need to purchase tire in addition....
If even one of them goes you get a Message that say that TPMS is inoperative. I never had a problem where all were functioning properly and it failed to detect and alert me to low pressure.
They are not overly sensitive in my experience. I think a PSI 3 pounds or more under will trigger it but not 1 or 2 pounds.
Provided TPMS is working, you will only get an error message if a tire falls outside of the programmed safety range. That range is pretty wide on my SL600, not sure what it would be on a 65; check the owners manual to be sure.
When I did my wheel upgrade, I replaced all 4 sensors last Winter at around $80 per sensor at Tire Rack. They carry the OEM Beru replacements for less than anywhere else I could find.
My TPMS was finicky before the new sensors, but have not had any issues since the new sensors over the past year. I realize now that was due to one or more sensors having weak batteries. Replace those sensors if your car is 5 or more years old and TPMS becomes a nice feature to have.
