SL55/63/65/R230 AMG: Eurocharged Stage 1 - How do they tune / map the car?
Old Nov 21, 2011 | 12:51 PM
Monky's Avatar
C63 Estate
Question Eurocharged Stage 1 - How do they tune / map the car?
Hi all,
Will be purchasing a stage 1 upgrade soon with 180mm pulley and ECU tune. I take it they just flash the stock ECU?
Is there no way they can live map the car on a dyno or would I be better tuning somewhere in England?
I don't want a random file flashed to the ECU as the climate is very different here and there will be many many variables between cars, how can they perfect the tune?
Anyone who has done this it would be really appreciated if you could give me more info.
Mods will be K&N, modified exhaust, circa 15psi, Johnson pump, UK weather
Cheers
T
Old Nov 21, 2011 | 01:25 PM
BRABUS786's Avatar
Stage 3 63
Hi
I'm based in Birmingham and am a UK dealer for Eurocharged and we keep most items in stock give me a call 07765 444447 or www.mslcentre.biz to chat and give you further advise
Thanks acid
Old Nov 21, 2011 | 03:48 PM
cal1's Avatar
SL55, ML500 & Acura TL
Originally Posted by Monky
Hi all,
Cheers
T
They should be able to dyno tune anywhere in the world I would guess. I am currently running an EC dyno tune. My car was on a dyno in Chicago and Jerry the EC tune guru was in Houston telling the dyno folks what values to adjust. hopefully, Brabus786 can help you with this.
good luck
Old Nov 22, 2011 | 08:31 AM
the head's Avatar
18 Titan XD 13 Cayenne TT 13 BMW HP4
Jerry can tune remotely. Give them a call.
Old Nov 22, 2011 | 11:31 AM
Monky's Avatar
C63 Estate
Perfect thanks for the info
Brabus did try calling but guessing your busy as it went to answerphone.
I need to order a Johnson cooler pump before I do anything, how much are they from you guys shipped to Chiswick London.
Cheers
Toby
Old Nov 23, 2011 | 12:21 PM
Chris-W's Avatar
sl55 AMG
Toby I have an almost new SL55 charger pump OEM that came off my car after only 2,000 miles when I changed my front bumper I went with a Johnson.
If you want it its yours for £50 and Im just up the road. C.
Old Nov 24, 2011 | 12:22 PM
Monky's Avatar
C63 Estate
Acid = top guy
