SL55/63/65/R230 AMG: hydraulic fluid
SL 55
hydraulic fluid
Hi, I am still having problems with my Hard Top. Does anyone have a DIY on checking the hydraulic fluid for that.
Any help will be highly appreciated
hydraulicfluid refill
can anyone advise where hydraulic fluid refill is located on sl55 and or do u have to take to dealer,,,,i am in remote area withoutdealer nearby,,,,,,ABC indication is fluid is low,,,
2005 SL55 AMG, 1986 Porsche 930S, 1996 Porsche 993tt
is on the trunk, remove the foam cover on the left to the tire. You will see the pump, there are 2 metric allen bolts, just remove them (forgot which one is for refill) and just add the fluid up to HALF of the container. After refill open and close the top and add hydraulic fluid if necessary. BTW you should search why your pump run out of fluid, LEAK?
