SL55/63/65/R230 AMG: Audio and interior upgrade with Canbus and OEM frame replacement
Old Feb 6, 2012 | 02:05 PM
nir's Avatar
nir
2008 s63
Please see threads above for your answers.
Originally Posted by freestylebiker3
i live in los angeles also.. and was looking to upgrade my audio system in my CL65..... few questions
did the keep the factory amp in the car and adapt the new amps together?
which shop did you use?
also for the 8 inch jl sub, im not sure where the factory sub is located in a SL but are you using this sub as a replacment/ direct bolt in? becuase my factory sub is in my rear deck, so i though i could just drop in the sub like your jl audio you have ( free air set up )
Old Feb 6, 2012 | 03:24 PM
OUTCAST's Avatar
SLK55AMG, SL600
Very nice work indeed!
Old Feb 6, 2012 | 07:24 PM
CHP_H8_ME's Avatar
'03 SL55. Wife drives '06 SL500 and Range Rover Evoque
I'm drouling here More Pic's of the working unit and steering controls display Please! (did that make sence?) Looking good so far!
Old Feb 6, 2012 | 07:31 PM
CHP_H8_ME's Avatar
Originally Posted by nir
Well, you' re welcome to come see it. Pm me.
PM sent...
Old Feb 6, 2012 | 10:37 PM
Sharkster's Avatar
Mercedes
Thanks for the info, guys.
The head unit looks really nice... and I also like the touchscreen. But if I can't use it plug-and-play with my OEM Bose system, then that's a No-No for me.
Good luck with your project, nir! Pics look great!
Old Feb 10, 2012 | 05:50 AM
greet's Avatar
SL55
SL55 Audio
Hi , i am new to this forum and have been reading your views and photos with interest. Just as a starter.. where is the Bose amplifier fitted please?
Old Feb 11, 2012 | 01:55 PM
  #32
nir's Avatar
nir
2008 s63
Thank you. The Bose amplifier is underneath the CDC changer behind the drivers seat.
Old Mar 9, 2012 | 06:35 PM
  #33
dsuder's Avatar
gps antenna
Hello
doing my own install now
I posted on the original thread about this unit.
where did they mount the GPS antenna??
after determining the Denison for my 2003 will not do much of the functions I wanted (like bluetooth), I decided to go all the way and do the full replacement surgery myself. There are actually seven speaker connections in this car. front door has mids and tweeters (4), center of dash and rear center (2) and subwoofer under passenger floor. So I bought (2) 4 channel amps, used 6 for regular speakers and bridged the last two for the sub. Ripped out the factory Bose CD changer and amplifier (all under rear compartment behind driver seat). Ran 4 channel audio cable and amp turn on wire through center console. I am using Boss PH2KD.4 amps because they (a) are very small and (b) the have low pass, high pass filters, freq cutoff adjustments, along with treble and bass boost all adjustable per two channels so you can really tweek the power and range getting to each speaker set. Car is totally apart still but the sound so far is awesome. Way more power that factory I believe. Steering controls work! Good news - the couplers they supply do directly connect to the factory harnesses. had to splice one wire (to actuate amplifiers) in harness, but no more.
Right now I am frustrated trying to find a way through the firewall so i can mount the GPS antenna in the air intake at the back of the hood (do not want it stuck to the dash if possible). Any help or ideas appreciated!!
Old Mar 26, 2012 | 08:09 PM
  #34
thouliares's Avatar
2013 SL 550 Diamond white
Smile seat shop
Enclosed are the seat pictures. The complete interior panels and carpets were painted black and the seats were recovered. The upholstery shop has the template for the seats, so he can ship them or if you are in so cal he can install them in 1 day. if any of you want to do this, pm me.
can you please give me the name and number of the shop that did your seats? they look great..
thx
Old Mar 26, 2012 | 08:11 PM
  #35
thouliares's Avatar
can you give me the name and number of the shop that did your seats? they look great!!
thx
Old Mar 26, 2012 | 08:15 PM
  #36
nir's Avatar
nir
2008 s63
you have an IM.
thx
Old Apr 26, 2012 | 03:16 PM
  #37
Girard@ACGautomotive's Avatar
a car
Excellent job on the interior. Love the way the seats are done.
Old Apr 26, 2012 | 03:22 PM
  #38
nir's Avatar
nir
2008 s63
Thank you very much. Great Job on your SL65 redo - big difference between the factory look and that. My car actually very similar, but with single slat grill, i had to change the front emblem because it disturbs the distronic. I love the comfort and the look of the seats. I also blacked out the complete interior - No more Grey for me. True Black on Black, the way it should have come from the factory!
Old Apr 28, 2012 | 02:27 AM
  #39
Thericker's Avatar
V12-Biturbo
Excellent work! I've already made an appt for interior! Thnku!!
Except I'm going ALL Alacantra/Suede w/Double red stitching top to bott... I've been looking everywhere & this guys prices & work are phenominal thnku very much bro!!!
Old Apr 30, 2012 | 06:41 PM
  #40
nir's Avatar
nir
2008 s63
Excellent! let me know how it goes. If it is anything like mine, you are going to be very happy! Make sure to share pics, will you?
Old Apr 30, 2012 | 10:14 PM
  #41
kustom2k1's Avatar
03SL55
nir, WOW! Smokin interior bro.
Old Apr 30, 2012 | 10:22 PM
  #42
kingnash's Avatar
03 SL55
nir, what did you do to your abc suspension and roof pumps?
Old May 1, 2012 | 12:57 AM
  #43
anotherAMG's Avatar
2003 Sl55 1995 C36
Those seats look awesome. I'll have to get that done at some point.
Old May 1, 2012 | 07:24 PM
  #44
nir's Avatar
nir
2008 s63
Thx very much to all for the complements - really updates the car and very comfortable drive.
Old May 1, 2012 | 07:28 PM
  #45
nir's Avatar
nir
2008 s63
Kingnash, My abc pump went out, so I had it replaced under the aftermarket warranty. The roof pump turned out to work but there was a leak in the pipes, so they landed up by replacing them under warranty as well. The headliner had lots of oil, but warranty refused to pay, so i had it dry cleaned and it took care of it!
Old May 1, 2012 | 07:29 PM
  #46
nir's Avatar
nir
2008 s63
Sure - when you are ready i will put you in touch with my guy, if you like. He in SFV about an hour from you.
Old Jun 26, 2012 | 12:10 PM
  #47
kilroy440's Avatar
2003 SL55 AMG
Hi Nir,
Love the look of your SL55. I have a 2003 SL55 AMG that I am considering upgrading with the cargpsnet aftermarket navigation unit that I believe you have. Now that you've had it for a couple months, what are your impressions of it? Can you play A2DP bluetooth audio while navigating?
If you were able to, a short Youtube video demo of the navigation interface on the unit would be great to see.
Thanks!
Old Jun 26, 2012 | 09:17 PM
  #48
nir's Avatar
nir
2008 s63
Thx Kilroy. Well since I have had so many requests, here is a video showing you guys the head unit functionality. Feel free to ask questions. hope this helps. It might take a few minutes to be active, as it is over 700 my in hd and 10 min long. Without the " " , please copy paste "http://m.youtube.com/#/watch?v=aOmpgNtUdOg"
Old Jun 26, 2012 | 11:18 PM
  #49
kustom2k1's Avatar
03SL55
Video is private
Old Jun 26, 2012 | 11:23 PM
  #50
nir's Avatar
nir
2008 s63
Video is private
Sorry try again, I made public
