SL55/63/65/R230 AMG: Don Nguyen | Clear headlight film protection - Prevent rock chips/cracks
Old Mar 19, 2012 | 03:42 PM
Don Nguyen's Avatar
Former Vendor of MBWorld
Euros
I know there are some of you out there who have no interest in the black vinyl roof wraps that I do or the way carbon fiber vinyl looks. However, you have to at least like protecting your car's headlights from rock chips and cracks.
The material that I use is not precut, so each and every installation is custom fitted to your car's specific application. This means no gaps or seam lines, in order to provide an invisible as possible installation result.
If there is enough interest, I may even be willing to do a group buy to start things out. Also, if your headlights are already faded and you wanted to restore it, I have a guy who can do that before the protective film is applied.
It was actually pretty hard figuring out a good way to show just how the clear film looks like on the headlights. However, hopefully this shows you just how clear and invisible the film is once applied to your headlights. I tried to make it as visible/noticeable as I could in this picture so you guys could actually see/notice the material.
thanks.
-Don
Donathon@gmail.com
Old Mar 20, 2012 | 07:28 AM
Z06KLR's Avatar
SL55 AMG
How does your film compare to other brands? What about those that don't live in Irvine, CA ?
Old Mar 20, 2012 | 12:51 PM
Don Nguyen's Avatar
Euros
I've personally used this material for several years on my own car without any issues. This is just the first time I've decided to offer it to customers. For those that aren't local, I can sell you the materials and you can DIY it.
Anything that I do, I offer the same materials that I would use as if I was doing the install.
-Don
Old Mar 20, 2012 | 02:29 PM
Z06KLR's Avatar
SL55 AMG
But not pre-cut ready to install pieces?
Old Mar 20, 2012 | 03:08 PM
Don Nguyen's Avatar
Euros
That's correct. I do not use pre cut pieces. I don't use them because as you are laying it onto the lighting pieces (or whatever you happen to be wrapping), if you stretch it or pull it slightly wrong, you'll end up losing material in another area, so you end up with gaps, etc.
-Don
