SL55/63/65/R230 AMG: RPM check
Old Jul 17, 2003 | 02:02 PM
Fast_Bubba's Avatar
2005 E55 Wagon
RPM check
I have finally gotten my car back after a supercharger failure. The supercharger was replaced, and the car seems to be running well. I was told that the system was likely never functioning well. Previously, I was running 2000 rpm @ 60 mph (100 km/hr) and continue to run at this engine rpm for the same speed. This is highway cruising and should be at the top gear. I have not tried this with the paddle shifting. Is this the same rpm range for this speed as the rest of you are getting or should I return to the dealer.
Thanks,
Robert
2003 SL55
2002 S430
Old Jul 17, 2003 | 09:46 PM
Matt230K's Avatar
2010 C300 4matic
Even without a supercharger at all, your RPM's will not change. That has to do with the gearing of the car, not the functionality of the supercharger.
Old Jul 17, 2003 | 10:20 PM
Fast_Bubba's Avatar
2005 E55 Wagon
Understood, but my Honda Odyssey is carrying less rpm at 60 mph than the SL55. It might be that the top gear is not engaging, or the car has not reached the point in the programming to shift to it. Regardless, I asked whether this was the experience of others with this engine. If so, I'm satisfied.
Old Jul 17, 2003 | 11:36 PM
Matt230K's Avatar
2010 C300 4matic
I agree that you should get an answer from someone with the same car to know for sure if it is correct. But I am willing to bet that it is correct RPM's. There are so many variables in the gearing of the car that any car can be different, Honda or MB. It depends on tranny, differential, wheel and tire size, etc.
Old Jul 18, 2003 | 11:41 AM
ajayz's Avatar
marta
I think 2000 at 60 sounds good.
