SL55/63/65/R230 AMG: Just bought sl55 got a problem!
Old Oct 18, 2012 | 11:17 AM
cal1's Avatar
SL55, ML500 & Acura TL
Originally Posted by AndreaAMG
Matt mine was doing the same thing. My amg mech looked it over completely, finding the motor mounts, thrust arm bushings and sleeves all in need of replacing. you feel it when you throttle due to the high torque, I'm told.
Exactly right! I think the piggish weight of our cars also contributes to wear on the thrust arm, bushings, sleeves, etc. The torque load on the tranny and motor mounts is significant and even worse on the modded engines like mine. Maybe that is why I am on my third set of motor mounts.
Old Oct 29, 2012 | 01:57 PM
cnterline's Avatar
2003 SL55,2020 GTC ,2017 GTS sold ,2002 G500 Sold,2003 SL500 Sold,
check the motor mounts as far as the vibration i have changed 3 sets of these in sl55 s
Old Oct 29, 2012 | 02:04 PM
cal1's Avatar
Three sets for you too. I don't feel so bad. Are you running mods?
Old Jun 16, 2013 | 03:37 AM
ALLANBROWN's Avatar
2007 SL55,2006 ML350
Some questions.
So no one makes better aftermarket motor mounts? Is there any diy for motor mount and trans mount changes. What does the dealership charge to change these? Would think motor mounts would be really expensive for labor?
Old Jun 16, 2013 | 10:49 PM
alx's Avatar
alx
Originally Posted by ALLANBROWN
Some questions.
No aftermarket mounts that meet or exceed updated oem mounts.
You don't need a DIY. You do need a lift and a tranny jack or two. Raise the car and take a look. They are self explanatory. You might need to raise a bit the engine and that is what th tranny jacks are for. More so on th v12tt cars. People have done it with ramps and engine hoist, but i have no experince with this method.
Th dealer will charge 4-6 hours for labor for the v8 and 6-8 for the v12.
Old Jun 16, 2013 | 10:51 PM
ALLANBROWN's Avatar
Ok so when did the updated mounts come in and are they a lot stronger?
Figured trans mount would be fairly simple to change they usually are and motor mounts can sometimes be a real bi##@.
Old Jun 16, 2013 | 10:53 PM
  #32
alx's Avatar
alx
I believe in 07. But I am not sure as I don't have epc in front of me. Th updated ones are supposed to be stronger. Not sure as I have seen them fail just like the old ones. I don't think you can even buy the old ones anymore.
The engine mounts are a ***** on the v8 and x2 on the v12tt cars. The tranny mount is easy.
