SL55/63/65/R230 AMG: Jacking up a SL55?
in the rear do not put a jackstand under the pumpkin. use the same spots as the fronts (under the lower control arms). again- lower carefully.
on jackstands vs. jacks for safety- you want the opposite for safe operation- never leave pressure on jacks- you want the car "planted" on the jackstands solidly _and_ prop the jacks as a backup (with little to no pressure on them).
the idea is that if a jack fails and the car slams on the jackstand (which you want to use as a backup) it might slide/slip and fall off the jackstand. so you want the other way around- planted on jackstands and use the jacks as backup.
and always put a wheel or two (if you removed them) under the car. it is your life- you cant have too many failsafes.
I've seen this wear patter more than i care to and it is always bad news...
