SL55/63/65/R230 AMG: SL 55 AMG Front Brake Rotors
Unless you are upgrading (cost more than OEM) I would go no less than OEM parts. parts.com is a good source, make sure you give them your VIN when ordering. Last time I did mine I went OEM rotors & Porterfield pads.
check ... http://www.ebay.com/itm/Mercedes-Benz-E55-SL55-03-06-AMG-Brake-Front-Rotors-Pads-Genuine-/120989959227?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item1c2b90443b
I really appreciate the recomendations. So a good route for me to go would be OEM rotors and Akebono Ceramic brake pads?? I have black wheels and cant stand the brake dust!
A little more advice before the rotor project!
What size Torx, Hex sockets will i need for rotor screws and calipers? And can someone send a pic of the SBC unit and harness to disable the system?
Appreciate the help, Thanks
Anyone know where to get just the rotor rings? My 2007 has the two piece factory front rotors like on the e63, c63 and sl63. I don't see a point in replacing the whole rotor when I can just replace the rings. These are the replacements I've found
http://www.ebay.com/itm/Mercedes-Benz-SL55-SL63-07-12-AMG-Brake-Front-Rotor-Rotors-Genuine-2194210212-/190850309802?pt=Motors_Car_Truck_Parts_Accessories&hash=item2c6f909eaa&vxp=mtr
00 C200 & 00 C55 & 06 SLK55
Try to contact "Warren" from RB racing brakes, he can help what ever you need..
http://www.racingbrake.com/Two-piece...ONT-p/2237.htm
ZAYED,,
ZAYED,,
ZAYED,,
ZAYED,,
EDIT Made the call and here is the 360mm that should work. They are telling me it is the same for 2008 and up C63 and E63.
http://www.racingbrake.com/Two-piece...ONT-p/2141.htm
