SL55/63/65/R230 AMG: Engine / radiator / suction fan troubleshoot
Old Jul 2, 2013 | 02:48 PM
FLGSHP7's Avatar
SL500
So my engine fan stopped working. I pulled the fan out and it looked fine and the motor seemed to be in good condition. Reinstalled and started playing with relays in drivers side fuse box(K40/2) and voila! It works. Well sorta. Now whenever I'm running AC the fan comes on but when AC is off, its a brick. Is this a coolant temp sensor? Anyone else had similar problems? TIA
P.S. I bought an extra used fan off ebay to help troubleshoot before i checked relays. Got it for a good price so its nice to have a spare around. I have had both fans in the car, same results.
Old Jul 2, 2013 | 07:40 PM
alx's Avatar
alx
Temperature activation is broken somewhere. The fan is coded to turn on with ac so that is why it works when you turn ac on.
Activate fan with das and follow the troubleshooting decision tree.
Old Jul 3, 2013 | 09:01 AM
FLGSHP7's Avatar
SL500
I'll be honest. I just googled "DAS." I had no idea. Mind blown! Thank you sir! I will post results as soon as I get the time.
Old Jul 3, 2013 | 10:14 AM
alx's Avatar
alx
Ah, yes. If you have a technical mind and you own a mercedes and fancy DIY, mind should be blown get a c3 or a c4 Chinese clone and pay it off the first time you use it.
