SL55/63/65/R230 AMG: SL55 IC pump relay and fuse location
Old Aug 23, 2013 | 06:57 PM
busaboy's Avatar
2004 SL55
2004 SL55, 13K miles
Can someone put up the Intercooler (charge air cooler) pump relay and fuse location? I bought a new pump but want to check the condition of the fuse and relay first.
Old Aug 23, 2013 | 07:56 PM
Duckman748's Avatar
SL55
Hook it up to run anytime the car is running. look for post for taillight fuse a couple of days ago. I put a fuse map on there
Old Aug 23, 2013 | 08:09 PM
busaboy's Avatar
2004 SL55
I don't see either the fuse or relay in the PDF you posted. Is there a different name for the pump?
I have another chart (attached) that shows it as F60. I cannot locate where it is. I cannot find a relay.
Old Aug 23, 2013 | 08:21 PM
Duckman748's Avatar
SL55
low temp pump f51 I think
Old Aug 24, 2013 | 09:59 AM
busaboy's Avatar
2004 SL55
That look right. Fuse is F51 and relay is R. They are under the passenger rear storage compartment.
Old Aug 25, 2013 | 08:53 PM
busaboy's Avatar
2004 SL55
The pump failed at about 11K miles. Replaced my factory original pump with the new version. Looks identical except it has a new venting system. Failure was due to the brushes in the pump motor being totally worn down. Would not think that could happen so soon. The pump relay had out of spec contact resistance too. No way to get a new one on the weekend so I burnished them and they are good now.
All is good now.
Old Jan 22, 2021 | 10:48 PM
Speed Mafia's Avatar
SL55 AMG
did this issue ever get resolved, just picked up a used 2004 sl55 and I noticed my air temps where 200 degrees 😳 so I purchased a new pump from fcp with coolant and swapped ot out but its not running? So I found the fuse box location behind the passenger area but not sure what Fuze to pull 🤔 or relay? The Fuse on mi e for 51 is 30amp? Not blown but going to replace regardless just incase... thoughts?
