SL55/63/65/R230 AMG: Add colant warning light.
Old Aug 24, 2013 | 03:55 AM
trauma1's Avatar
Mazda Rx7, Mercedes SL55 AMG
I am getting a add coolant warning in the car.
The car is not missing any coolant. And temp is stable around 90°C
The car is recently had a widebody conversion, and the washer fluid tank had to be removed.
The washer tank was removed due to space, and the coolant hose was just connected together again, with a pipe.
Mercedes here in Norway have no idea what the problem is.
But then again, these cars are not common in Norway due to high taxes.
Is there any way to find out witch sensor that is triggering the warning?
Or any suggestion on were the problem can be?
Nick
Old Aug 24, 2013 | 10:45 PM
WHTEVO's Avatar
07' SL65, 04' E55, 03' Evo8, 08' GSXR, DSM's...
There is a sensor in the coolant reservoir. You may need to ground out one of the wires that went to the sensor to fool it into thinking its full. Good luck.
