SL55/63/65/R230 AMG: Too much oil consumption
I am using Total Quartz 7000 5w40, I am afraid that the quality of the oil isn't good enough, and actually thinking of using Fuchs 5w40 supersyn instead. Would the oil quality play a role in this case?
I am also afraid that the oil measurement sensor isn't true, and I actually can't find an oil dipstick for my car in Lebanon, how can I make sure the oil level is fine or not?
Now lets assume the engine is consuming this oil, should I thicken the oil used to 10W40 or 15w40? Should I use "Liqui Moly oil re-sealer (it rejuvenates stem seals, and head gasket)"?
Thank you a lot for any help offered!
Best Regards,
Jad
Do not use thicker than recommended oil in an effort to reduce consumption. Try mobil one 0w40 but I am suspicious your problem is not the oil. A liter per couple hundred kilometers means your motor has serious issues.
Have compression checked for low compression at neighboring cylinders. Have the valve covers off and check valve guides health.
It could be many things but the two checks above are what needs to be done first assuming your oil level indicator is not bad. It can be checked by reading it with das sand adding a quart of oil when says it is low. Then read it again- if reading went up a quart your sensor is good.
