SL55/63/65/R230 AMG: Android Torque Application Test Reading Interpretation
I recently purchased an OBD II reader and am using it with the Android Torque application. I have no fault codes showing, however, on a separate monitoring test I've consistently received FAILS and unfortunately with a lot of searching through forums and other parts of the web have not been able to determine what it means. I'm hoping someone might be able to help before I go down a real rat hole trying to figure it out. These are FAIL messages I get in the test.
MID:$0e TID:$33
- O2 Bank 4 Sensor 2
Max: 817.90002g Min: 5,543.2002g
Test result value: 6,552.30029g
FAIL
MID:$3c TID:$81
- EVAP Monitor (0.040")
Test incomplete or dependant test failed
MID:$81 TID:$40
- Fuel System Monitor Bank 1
Max: -2,457.6001 Min: 2,667.19995
Test result value: 1,561.59998
FAIL
MID:$81 TID:$45
Max: 1 Min: 24,657
Test result value: 17,792
FAIL
MID:$83 TID:$99
- Fuel System Monitor Bank 3
Max: 24,555 Min: 22,600
Test result value: 65,520
FAIL
My first reaction was incorrect fuel mix, so put some high quality additives into my fuel with no change. If I had to guess it looks like several of my oxygen sensors aren't working properly but not sure what to do with the information.
The vehicle is a 2009 SL63 with 30,000 miles. It seems to run well and I haven't seen a performance difference recently, but I've only had it for about 3,000 miles so it could have been like this when I bought it and wouldn't know the difference. I've done a few 0-60's also using Torque as the reader and have been in the 5.5 - 6.0 second range which I know is slow but that could be just my poor driving.
Here are the full test results (sorry it is lengthy but might provide some additional context?) As you can see, lots of PASS as well, but also the FAIL results.
Any help anyone could provide is greatly appreciated.
James
Test report:
MID:$01 TID:$83
- O2 Bank 1 Sensor 1
Max: 1.99882 Min: 0.44969
Test result value: 1.21195
PASS
MID:$01 TID:$84
Max: 0.04499 Min: -0.04499
Test result value: -0.00598
PASS
MID:$02 TID:$01
Rich to Lean sensor threshold voltage(constant) - O2 Bank 1 Sensor 2
Max: 0.63538V Min: 0.63538V
Test result value: 0.63538V
PASS
MID:$02 TID:$02
Lean to Rich sensor threshold voltage(constant) - O2 Bank 1 Sensor 2
PASS
MID:$02 TID:$05
Rich to Lean sensor switch time(calculated) - O2 Bank 1 Sensor 2
Max: 65,535ms Min: 0ms
Test result value: 40ms
PASS
MID:$02 TID:$07
Minimum sensor Voltage for test cycle(calculated) - O2 Bank 1 Sensor 2
Max: 0.44969V Min: 0V
Test result value: 0V
PASS
MID:$02 TID:$08
Maximum sensor Voltage for test cycle(calculated) - O2 Bank 1 Sensor 2
Max: 1.1185V Min: 0.44969V
Test result value: 0.95441V
PASS
MID:$02 TID:$81
Max: 0.64026V Min: 0V
Test result value: 0.6305V
PASS
MID:$02 TID:$82
Max: 1.1185V Min: 0.64026V
Test result value: 0.65002V
PASS
MID:$02 TID:$83
Max: 0.14933V Min: 0V
PASS
MID:$02 TID:$86
Test result value: 1,210ms
PASS
MID:$05 TID:$83
- O2 Bank 2 Sensor 1
Test result value: 1.10996
PASS
MID:$05 TID:$84
Test result value: -0.00982
PASS
MID:$06 TID:$01
Rich to Lean sensor threshold voltage(constant) - O2 Bank 2 Sensor 2
PASS
MID:$06 TID:$02
Lean to Rich sensor threshold voltage(constant) - O2 Bank 2 Sensor 2
PASS
MID:$06 TID:$05
Rich to Lean sensor switch time(calculated) - O2 Bank 2 Sensor 2
Test result value: 30ms
PASS
MID:$06 TID:$07
Minimum sensor Voltage for test cycle(calculated) - O2 Bank 2 Sensor 2
PASS
MID:$06 TID:$08
Maximum sensor Voltage for test cycle(calculated) - O2 Bank 2 Sensor 2
Test result value: 0.9494V
PASS
MID:$06 TID:$81
PASS
MID:$06 TID:$82
PASS
MID:$06 TID:$83
PASS
MID:$06 TID:$86
Test result value: 1,230ms
PASS
MID:$21 TID:$84
- Catalyst Monitor Bank 1
Max: 65,535 Min: 3,277
Test result value: 6,562
PASS
MID:$22 TID:$84
- Catalyst Monitor Bank 2
Test result value: 6,561
PASS
MID:$39 TID:$80
Max: -2,048 Min: -32,768
Test result value: -2,198
PASS
MID:$3b TID:$81
- EVAP Monitor (0.090")
Max: 2,455 Min: -32,768
Test result value: 363
PASS
MID:$3c TID:$81
MID:$3d TID:$88
- EVAP Monitor (0.020")
Max: -164 Min: -32,768
Test result value: -199
PASS
MID:$3d TID:$8c
Max: 32,767 Min: -7,373
Test result value: -160
PASS
MID:$41 TID:$85
- O2 Heater Monitor Bank 1 - Sensor 1
Max: 1,302.80005°C Min: 759.90002°C
Test result value: 820°C
PASS
MID:$42 TID:$81
- O2 Heater Monitor Bank 1 - Sensor 2
Max: 1,184Ohm Min: 0Ohm
Test result value: 126Ohm
PASS
MID:$45 TID:$85
- O2 Heater Monitor Bank 2 - Sensor 1
Test result value: 819.79999°C
PASS
MID:$46 TID:$81
- O2 Heater Monitor Bank 2 - Sensor 2
Max: 1,216Ohm Min: 0Ohm
Test result value: 124Ohm
PASS
MID:$71 TID:$80
- Secondary Air Monitor 1
Max: 1.99882 Min: 0.20301
Test result value: 1.51475
PASS
MID:$72 TID:$80
- Secondary Air Monitor 2
Test result value: 1.44448
PASS
MID:$01 TID:$48
Max: 4,096 Min: 2,667.19995
FAIL
MID:$01 TID:$83
PASS
MID:$01 TID:$84
Test result value: -0.00601
PASS
MID:$02 TID:$01
Max: 0.62562V Min: 0.62562V
Test result value: 0.62562V
PASS
MID:$02 TID:$02
PASS
MID:$02 TID:$05
PASS
MID:$02 TID:$07
PASS
MID:$02 TID:$08
PASS
MID:$02 TID:$81
Max: 0.62562V Min: 0V
Test result value: 0.61586V
PASS
MID:$02 TID:$82
Max: 1.1185V Min: 0.62562V
PASS
MID:$02 TID:$83
PASS
MID:$02 TID:$86
Max: 65,520ms Min: 15ms
Test result value: 21,600ms
PASS
MID:$05 TID:$83
PASS
MID:$05 TID:$84
Test result value: -0.00985
PASS
MID:$06 TID:$01
PASS
MID:$06 TID:$02
PASS
MID:$06 TID:$05
PASS
MID:$06 TID:$07
PASS
MID:$06 TID:$08
PASS
MID:$06 TID:$81
PASS
MID:$06 TID:$82
PASS
MID:$06 TID:$83
PASS
MID:$06 TID:$86
Test result value: 24,800ms
PASS
MID:$0e TID:$33
FAIL
MID:$21 TID:$84
PASS
MID:$22 TID:$84
PASS
MID:$39 TID:$80
PASS
MID:$3b TID:$81
PASS
MID:$3c TID:$81
MID:$3d TID:$88
PASS
MID:$3d TID:$8c
Test result value: -67
PASS
MID:$41 TID:$85
Test result value: 820.20001°C
PASS
MID:$42 TID:$81
Max: 840Ohm Min: 0Ohm
Test result value: 118Ohm
PASS
MID:$45 TID:$85
Test result value: 821°C
PASS
MID:$46 TID:$81
Test result value: 122Ohm
PASS
MID:$71 TID:$80
PASS
MID:$72 TID:$80
PASS
MID:$81 TID:$40
FAIL
MID:$81 TID:$45
Max: 1 Min: 24,657
FAIL
MID:$81 TID:$80
Max: 4.5% Min: -4.5%
Test result value: 2.67%
PASS
MID:$81 TID:$82
Max: 1.29924 Min: 0.69961
Test result value: 0.96536
PASS
MID:$82 TID:$80
- Fuel System Monitor Bank 2
Test result value: 0.37%
PASS
MID:$82 TID:$82
Test result value: 1.01025
PASS
MID:$83 TID:$99
FAIL
MID:$a2 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 1 Data
Max: 65,535Count Min: 0Count
Test result value: 0Count
PASS
MID:$a2 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 1 Data
PASS
MID:$a3 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 2 Data
PASS
MID:$a3 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 2 Data
PASS
MID:$a4 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 3 Data
PASS
MID:$a4 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 3 Data
Test result value: 1Count
PASS
MID:$a5 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 4 Data
PASS
MID:$a5 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 4 Data
PASS
MID:$a6 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 5 Data
PASS
MID:$a6 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 5 Data
PASS
MID:$a7 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 6 Data
PASS
MID:$a7 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 6 Data
PASS
MID:$a8 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 7 Data
PASS
MID:$a8 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 7 Data
PASS
MID:$a9 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 8 Data
PASS
MID:$a9 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 8 Data
PASS
End Report
MID:$0e TID:$33
FAIL
MID:$3c TID:$81
MID:$81 TID:$40
FAIL
MID:$81 TID:$45
Max: 1 Min: 24,657
FAIL
MID:$83 TID:$99
FAIL
James
Test report:
MID:$01 TID:$83
PASS
MID:$01 TID:$84
PASS
MID:$02 TID:$01
PASS
MID:$02 TID:$02
PASS
MID:$02 TID:$05
PASS
MID:$02 TID:$07
PASS
MID:$02 TID:$08
PASS
MID:$02 TID:$81
PASS
MID:$02 TID:$82
PASS
MID:$02 TID:$83
PASS
MID:$02 TID:$86
PASS
MID:$05 TID:$83
PASS
MID:$05 TID:$84
PASS
MID:$06 TID:$01
PASS
MID:$06 TID:$02
PASS
MID:$06 TID:$05
PASS
MID:$06 TID:$07
PASS
MID:$06 TID:$08
PASS
MID:$06 TID:$81
PASS
MID:$06 TID:$82
PASS
MID:$06 TID:$83
PASS
MID:$06 TID:$86
PASS
MID:$21 TID:$84
PASS
MID:$22 TID:$84
PASS
MID:$39 TID:$80
PASS
MID:$3b TID:$81
PASS
MID:$3c TID:$81
MID:$3d TID:$88
PASS
MID:$3d TID:$8c
PASS
MID:$41 TID:$85
PASS
MID:$42 TID:$81
PASS
MID:$45 TID:$85
PASS
MID:$46 TID:$81
PASS
MID:$71 TID:$80
PASS
MID:$72 TID:$80
PASS
MID:$01 TID:$48
FAIL
MID:$01 TID:$83
PASS
MID:$01 TID:$84
PASS
MID:$02 TID:$01
PASS
MID:$02 TID:$02
PASS
MID:$02 TID:$05
PASS
MID:$02 TID:$07
PASS
MID:$02 TID:$08
PASS
MID:$02 TID:$81
PASS
MID:$02 TID:$82
PASS
MID:$02 TID:$83
PASS
MID:$02 TID:$86
PASS
MID:$05 TID:$83
PASS
MID:$05 TID:$84
PASS
MID:$06 TID:$01
PASS
MID:$06 TID:$02
PASS
MID:$06 TID:$05
PASS
MID:$06 TID:$07
PASS
MID:$06 TID:$08
PASS
MID:$06 TID:$81
PASS
MID:$06 TID:$82
PASS
MID:$06 TID:$83
PASS
MID:$06 TID:$86
PASS
MID:$0e TID:$33
FAIL
MID:$21 TID:$84
PASS
MID:$22 TID:$84
PASS
MID:$39 TID:$80
PASS
MID:$3b TID:$81
PASS
MID:$3c TID:$81
MID:$3d TID:$88
PASS
MID:$3d TID:$8c
PASS
MID:$41 TID:$85
PASS
MID:$42 TID:$81
PASS
MID:$45 TID:$85
PASS
MID:$46 TID:$81
PASS
MID:$71 TID:$80
PASS
MID:$72 TID:$80
PASS
MID:$81 TID:$40
FAIL
MID:$81 TID:$45
Max: 1 Min: 24,657
FAIL
MID:$81 TID:$80
PASS
MID:$81 TID:$82
PASS
MID:$82 TID:$80
PASS
MID:$82 TID:$82
PASS
MID:$83 TID:$99
FAIL
MID:$a2 TID:$0b
PASS
MID:$a2 TID:$0c
PASS
MID:$a3 TID:$0b
PASS
MID:$a3 TID:$0c
PASS
MID:$a4 TID:$0b
PASS
MID:$a4 TID:$0c
PASS
MID:$a5 TID:$0b
PASS
MID:$a5 TID:$0c
PASS
MID:$a6 TID:$0b
PASS
MID:$a6 TID:$0c
PASS
MID:$a7 TID:$0b
PASS
MID:$a7 TID:$0c
PASS
MID:$a8 TID:$0b
PASS
MID:$a8 TID:$0c
PASS
MID:$a9 TID:$0b
PASS
MID:$a9 TID:$0c
PASS
End Report
2006 sl55 030 option - sold
You are looking at mode 6 data. This should be looked at if you have a light on or have a problem that is intermittent or is hard to figure out. Mode 6 data also needs to be deciphered. The number value your looking at may be correct or it may need to be deciphered($.). To try and explain this would be long and drawn out.
You say you don't have a light on now , so I would not worry.
I hope this helps
I hope this helps
Thank you coldwell
It does help. I wasn't certain whether it was something I needed to worry about or not so knowing this can let me put it to rest. Appreciate your response.
James
James
Another thing that would be good to do is look at the LIVE data and get use to the values on the screen and how they change. long term and short term fuel trim (STFT LTFT ) is a real great value to study and know. have fun with new tool.
Hope this also helps.
Thanks! I've set up a dashboard that provide real time STFT and LTFT. Also read a couple of articles that gave me a better understanding of how the pieces fit together. Haven't taken it to the road yet, but looking forward to it. Thanks again for your help, much appreciated!
James
James
